Class action lawsuit.
My issues are mostly with the GPS. Now and again the map will show turning right but the text says to turn left (and vice versa) . . . Go Figure . . . Usually (but not always) the map is correct. I also have experienced that the "Find a Harley Dealer" function is inaccurate . . . and the Dealer knows this . . . so one would assume that the dealer would let Harley know about it. Ex: Beartooth Harley Davidson at the northern entrance to Yellowstone National Park . . . off by about a quarter mile and on the wrong side of the street . . . Duh! So I called them and I said, " where are you guys" and they said "you must be using your Harley GPS, because they all have that problem."
All good points, I don't think there are enough having YOUR share of issues to cause a class action lawsuit,, unless we name the "Glare" problem in it,, but I believe most of us knew it was an issue before we bought our Road Glides,, we wanted a Shark Nose more than to see the radio screen 100% of the time!
Blue Tooth,, um, you realize that is a radio signal,, correct? It deteriorates going THROUGH objects,, (IF it even can) and there is nothing around you on the highway for it to bounce off off. You are between it and the radio when it's in your tour pack,,,, Just a thought on that problem. Unless you are only 5' tall and 90 lbs,, maybe then it's not an issue after all.
The other issues,, I'd simply use my other technology I love so much. (I Phone camera) and record the time of every issue the nav locks up,, document, document, document. GO to your best dealer, and if they say the MOCO won't let them fix it. CALL MOCO... the dealer is not your problem if they are speaking the truth and MOCO won't let them, ie... reimburse them for the repair/ replacement.
A large cup of water with the radio powered on could potentially solve your problem
After all bikes can be ridden in the rain
Just make certain it actually rains first
Good luck with the suit.....
is it really 50% of the time on Bluetooth failures or do you have a failure of this function every time you ride for a few minutes? 90% is a real # i am surprised when you say that i have not found that 90% of the dealers are wrong on my GPS.
maybe your just blowing smoke and that 's alright too but if your serious line things up ,document it and move forward.
