Quick question on clutch cable...
Old Sep 4, 2015 | 01:59 PM
FlamedFXR's Avatar
FlamedFXR
Default Quick question on clutch cable...
Is it a wear item? When I bought the Road Glide used from a dealer (24 thou miles) they said they replaced the clutch cable. Wondering if I should replace it as a precaution, I now have 73 thou miles. I lube it every 10 thou when I change the tranny fluid.
Old Sep 4, 2015 | 02:09 PM
mkguitar's Avatar
mkguitar
if it is smooth and not stretching, I'd leave it.
if concerned buy a replacement so you have it on hand...and swap on your next tranny fluid change.
if you have to swap inbetween changes, roll up your wheels of a 2x4 and put the bike on the jiffy ( make sure it is stable)...you can pull the trap door cover without loosing fluid.
make sure your cable is correct length- lay it out next to the old one.
and follow the routing exactly
( we had one rider install his cable wrong, on a left turn out of a driveway, the cable looped around his turn signal...and held the bars to the left. he crashed)
mike
Old Sep 4, 2015 | 10:25 PM
FlamedFXR's Avatar
FlamedFXR
Do the replacement HD cables need to be lubed? I understand some are teflon coated or something.
clap
Mar 20, 2016 04:04 PM
Scudda
Sep 29, 2015 01:20 PM
justinmark79
May 17, 2009 08:02 AM
harley-jones
Oct 1, 2008 06:47 PM
John3:16
Nov 17, 2007 08:41 PM
