Engine cooling fan
Old Sep 13, 2011 | 09:12 PM
speakerfritz's Avatar
speakerfritz
I have one. Works big time. Best if wired backwards. Normal wiring pushes the air from left to right which results in hotter air being blown into your intake. If you wire backwards...air blows from right to left and pulls cold air into your intake. Also, bypassed the sensor and wired directly to the ACC switch via a relay.
Old Sep 13, 2011 | 09:14 PM
speakerfritz
Originally Posted by mistermooster
I don't know what you're riding, but I found out after ordering one, that they do not fit the '07 96" motor! You'd at least have to fabricate a new lower mount. I sent mine back. I sure could use it here in the summer.
sounds like you had an incomplete kit. my kit had two different mounts and one was specificaly for 07's with 96" engines.
Old Sep 13, 2011 | 09:41 PM
2black1s's Avatar
2black1s
I have a LeNale Cooling fan on my bike and it works great. And it looks much cleaner than the HD version.
Where I live I think the fan is a must have.
Here's a link to a thread I wrote documenting the performance of the fan.
https://www.hdforums.com/forum/touri...test-data.html
Old Oct 17, 2011 | 12:21 PM
tttnl56283416's Avatar
tttnl56283416
2nd Gear
Originally Posted by HDJoe
Hey, has anyone have the HD engine cooling fan that mounts where the horn is. If so does it really work or worth the $400 somthing price tag. Thanks.
I installed an engine fan [parade fan] on my ultra classic back in 2007 and it has not overheated since. I live in Florida and it made a hell of a difference. You have to get used to the hot air blowing across an already hot engine. So I would not advise wearing shorts on a hot day [or any day at all for that matter]. In summary if you are overheating the 400+ investment is well worth it.
Old Oct 17, 2011 | 12:28 PM
speakerfritz
Originally Posted by Ram
I have the H-D cylinder fan and the H-D premium oil cooler. I recommend them highly. They work for me. The way I see it, every little bit helps.
ditto. but it depends on your riding conditions. if you have a lot of stop and go traffic then you need it. if you are in wide open spaces then you don't.
Old Oct 17, 2011 | 02:22 PM
Bodean46's Avatar
Bodean46
I've had the Lenale fan on mine for 3 years. Never skips a beat and works wonders in heavy stop and go traffic, ( got a great work out in Denver in July and again in Sturgis this year.) Motor never overheated and the wife said she never noticed the heat coming off the motor.
Old Oct 17, 2011 | 07:41 PM
62hdbiker's Avatar
62hdbiker
I have the HD parade fan on my FLHTK. Just got home from Daytona. In heavy traffic my dash temp gage climbed to 230 deg. I flipped fan on and it stopped climbing. Others here, without a fan say 260 - 280 deg is normal. Not for me.
Old Oct 17, 2011 | 07:47 PM
PistonPuller's Avatar
PistonPuller
Or maybe they just didnt make the mounts 4 years ago when he wrote that.
roysclockgun
Jun 30, 2021 10:19 AM
Dannell53
Dec 14, 2016 12:10 PM
MNPGRider
Jun 9, 2014 10:57 AM
homyakchik
Sep 7, 2012 08:07 PM
mrwizard
Oct 28, 2007 01:37 PM
