05 roadking
Old Sep 29, 2015 | 12:01 PM
Joddie's Avatar
Joddie
Stage I
Question 05 roadking
We put a new regulator and stator on and the bike still won't hold a charge ......anyone know if there is something else that we could be missing ????
Old Sep 29, 2015 | 12:09 PM
mkguitar's Avatar
mkguitar
charge the battery with a charger...a 3 to5 amp charge rate for a day.
then load test the battery at autozpne for free.
check the battery cables.
a bad battery can destroy a stator or VR, so we have to know the battery is good
once we know the battery and cables are good we check the stator and VR
the HDForums tech board has an electrical section with charging system checks...requires a volt/ ohm meter and 20 minutes
Mike
Old Sep 29, 2015 | 12:41 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Did you test the battery first? Always start with the simplest.
Then did you perform proper diagnostics on the regulator and stator before changing them? Or are you just throwing parts at it hoping something sticks?
Old Sep 29, 2015 | 12:52 PM
Ragtop's Avatar
Ragtop
I would hope that the OP at least changed or load tested the battery before
replacing expensive parts!
Old Sep 29, 2015 | 01:56 PM
GTK's Avatar
GTK
Well,I wouldn't bet on it.
sixgun95
Mar 3, 2019 10:14 AM
Khshockey44
Electrical/Lighting/Alarm
Aug 19, 2018 02:15 PM
CarolinaThunder
Jan 27, 2015 02:39 PM
Mars47
Jul 2, 2014 11:24 PM
andyp
Sep 12, 2010 10:52 AM
