Help with engine noise under load
Old Oct 18, 2015 | 09:32 AM
stic2it's Avatar
stic2it
Default Help with engine noise under load
I have a noise under load at a out 2k rpm and up but only when tire moving. I can't replicate when idling, in or out of gear. It sounds like an exhaust leak, or air leak with metal high pitch rattle. I can hear it on the highway when it's under load. If I let off the gas, I can't hear a thing. I had the rear come up low compression, rings not sealing but was torn down and fixed. The front was fine so I didn't touch it as recommended by a builder. WOT I hear what sounds like gravel in the front cylinder. I had the bike dyno'd the end of last year but the noise started May this year, tuner said I would not need to adjust the tune after fixing the rear cylinder. I tore down the cam chest but stopped short of checking out the oil pump, pressure has been fine. I have an old tune from FM that I was going to try and see if the gravel noise is a detonation problem. Build is an FM 107, bike pulls and rides like nothing is wrong.
Old Oct 18, 2015 | 09:53 AM
Eunoterpsia's Avatar
Eunoterpsia
Another Rockout Rocker Locker Customer... Spend the 15 bones on amazon... buy 8 new bolts, new rocker cover gaskets from the moco (for insurance/assurance), and the oil filter kit (filter element, 2 gaskets for each jug) and that may just solve your problems.
Old Oct 18, 2015 | 03:18 PM
stic2it's Avatar
stic2it
I don't have valve train noise, I'm thinking maybe a bearing but it doesn't fit the symptoms of the common bearing failures.
Old Oct 18, 2015 | 04:26 PM
xcbullet's Avatar
xcbullet
If it is detonation should be able to tell by looking in spark plug holes with small flex light. Tops of pistons will look like they have been sand blasted. Should be signs of it on spark plugs as well but harder to tell.
Old Oct 18, 2015 | 08:15 PM
Eunoterpsia
have you put the whip on a lift, got under the bike and rotated the tire...
Old Oct 19, 2015 | 05:51 AM
stic2it's Avatar
stic2it
Oh yeah she has been on a lift a lot since May. The noise completely goes away if no throttle is applied. Clutch in or out. I get It only under load
Old Oct 21, 2015 | 03:52 PM
IrishHogtrotter's Avatar
IrishHogtrotter
Sounds like a detonation problem
Old Oct 21, 2015 | 04:50 PM
QNman's Avatar
QNman
Agree with Irish - if only under load, sounds like detonation to me.
Old Oct 21, 2015 | 06:54 PM
nytryder's Avatar
nytryder
What yr and type of HD is having the problem?
Old Oct 21, 2015 | 07:15 PM
BLKPRLFLHTCU's Avatar
BLKPRLFLHTCU
Change to a different gas station, make sure there is no ethanol in their fuel. Maybe a bit of octane booster in the next tank if a different gas station doesn't help. If it is a detonation related noise it should change the sound. Is the compression in the two cylinders even within spec?
