Re-using rear floorboardn inserts HELP
Old Oct 27, 2015 | 09:35 AM
txsnafu's Avatar
txsnafu
Stage III
Default Re-using rear floorboardn inserts HELP
Traded my '12 Limited and got a '16 Road Glide Ultra. Stripped the old bike of as much as I could including floorboards. Got front floorboards changed but can't get the rears to seat completely. When they're new they have a longer nipple that can be pulled through the small hole and once seated cut off. I don't have the extra nipple and can't get the small round nipple through the hole in the pan. Soaped, WD40'd tried everything slick (short of grease) and can't get the nipples pulled through.
Anyone faced this before or have suggestions?
Thanks
Old Oct 27, 2015 | 09:59 AM
14GuineaPig's Avatar
14GuineaPig
Can you wrap a piece of fishing line around the nipple?
Old Oct 27, 2015 | 10:45 AM
tj316's Avatar
tj316
I put a thin piece of string around mine , pulled it through then cut the string off
Old Oct 27, 2015 | 12:35 PM
mkguitar's Avatar
mkguitar
for lube use lighter fluid.
it'll lube then evaporate dry and clean
mike
Old Oct 27, 2015 | 01:37 PM
Ragtop's Avatar
Ragtop
When I clicked here, I never thought it would be a thread about lubing nipples!
digdug
Mar 22, 2016 09:27 PM
Gunner B
2014-2024 Touring Models
Jun 22, 2014 11:07 PM
duoglider
General Topics/Tech Tips
Oct 26, 2010 10:41 PM
ROLLNTIGER
Feb 11, 2008 11:42 PM
