I have the rubber ring type & have used it over & over again. The key is to not over tighten the screws. There is no oil pressure behind there trying to leak out... just some splashing going on.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
