Ultra Fork leaking ?
Old Nov 11, 2015 | 11:29 AM
djss's Avatar
djss
Default Ultra Fork leaking ?
I have a 12 Ultra Classic that I just rode on a 2300 mile trip. I noticed on the way home the fork on the right side was oily near the top. I wiped it off and it appears to be leaking near the top. I took the cover off to check and make sure the big fork nut was tight and it was. I am hoping this is as simple as a fork oil change and replace the seal under the fork nut. I have my doubts that it will be that easy. Has any one encountered this and where is the most likely place they leak.
Thanks
Old Nov 11, 2015 | 11:57 AM
lp's Avatar
lp
If it is not leaking from under the cowbell, all it probably needs is a new o-ring seal that goes under that large bolt at the top.
Old Nov 11, 2015 | 01:05 PM
tenn volunteer's Avatar
tenn volunteer
I have had 4 new HD touring bikes since 2007. My 13 CVO Ultra needed both fork seals changed at different times, six months apart. I thought it odd that both would leak. No fork seal problems with the others. 27,000 miles on the 07 Road King, 48,000 miles on the 09 Ultra, 32,000 miles on the CVO, and 17,000 miles on the Low.
Old Nov 11, 2015 | 04:35 PM
djss's Avatar
djss
I cleaned up the oil and rode it today so I could pay close attention to where it is leaking. The black area in the photo is dry, it is leaking between the black and the chrome just an inch or so below the top of the fork. I was hoping I could just take the top nut off and replace the seal below it but I don't think so.
Old Nov 11, 2015 | 05:00 PM
IrishHogtrotter's Avatar
IrishHogtrotter
its probably the o ring under the fork cap, if its not the filling nut one you have checked. I had the same on a 09. I found the fork cap bolt was finger tight.
If its loose you might get away with sliding the leg down a few inches and tightening it, if not then the leg needs to some out.
Not a major job, but means pulling the leg out to give you room to re-insert it. The fork cap is under spring tension so be careful when unscrewing....it will come off with gusto if you're not...lol. Reinserting the cap nut needs a bit of weight behind it because of the spring tension.
Old Nov 11, 2015 | 07:09 PM
harley0711's Avatar
harley0711
I had a 04 and have had the forks off several times - the top nut/bolt is the one that holds the fork to the triple tree - that takes a large wrench and can be a pain to get to... the insert threaded part is the one that is under pressure... So, If the O-ring on the first one is only needed - that is an easy and fast fix - no need to remove the fork. of course if the inner insert is the problem child, then yes, fork needs to come out and be careful.
on the 14 + bikes... top of the fork is different - that Big nut is NOT there....
Old Nov 11, 2015 | 07:20 PM
TSheff's Avatar
TSheff
Pretty much a DITTO here. Change the fill cap O-ring and go riding.
If it still leaks fork comes off. If you can pad it and clamp it and can handle the removal safely (BEWARE the SPRING TENSION) - go for it, and same for assembly. Or run it to your local independent for a quick off and on.
Old Nov 12, 2015 | 08:17 AM
djss's Avatar
djss
Thanks
The weather is still warm so I am going to wait a few days to tear into it.
Old Nov 12, 2015 | 05:45 PM
Sparkee...'s Avatar
Sparkee...
I thought my forks were leaking but it ended up being bad grease I put in the steering head bearings on my 10,000 mile service. I do know better, but I bought a tube of Harley grease since I though just maybe they formulated it specifically for the steering head bearing. Over time the oil separated from the "binding" agent, possibly in the heat, leaking the oil all down the side of my bike while on a trip. When I got home I picked up my grease gun and about a half a cup of oil poured out the bottom. I went back to using the multi purpose synthetic grease I've been using on heavy equipment for years, I have never seen it separate even in the hottest conditions.
FL-kruzen
Oct 12, 2012 05:45 AM
DWhite
Apr 22, 2008 03:52 PM
mcman
Apr 23, 2007 12:43 AM
rdrunner
Jun 5, 2006 11:44 AM
billnourse
Oct 9, 2005 12:50 PM
