Ignition Switch Cover Problem
Old Nov 16, 2015 | 07:27 AM
roundy's Avatar
roundy
Default Ignition Switch Cover Problem
Afternoon all,
My '02 Road King ignition switch will not click closed anymore because the little u-shaped piece of metal has snapped. I've removed the broken piece but need suggestions of how to replace it, I can't see it listed anywhere as a part.
Mu current thinking is to try a small split pin?
Old Nov 16, 2015 | 10:35 AM
JMC22's Avatar
JMC22
Try Ronnies to see better detail of the parts - maybe this will help you
http://partsfinder.onlinemicrofiche....=47&c=0&d=2002 FLHRI TOURING ROAD KINGŽ (INJECTION) (FB) INSTRUMENT ASSEMBLY
Old Nov 16, 2015 | 11:05 AM
69cj's Avatar
69cj
Nope, roundy is just looking for the clevis pin that goes inside part#23. I have the same problem but I'll live with it as long as the lid stays shut. Then I have an old ignition switch that I'll exchange the bodies with. Just to lazy right now to pull the center strip apart to do it.
Old Nov 16, 2015 | 03:57 PM
dyna rider's Avatar
dyna rider
Default Part Number 23
Part number 23 is the electrical connection for the fuel gauge...You mean 21 ?
Old Nov 16, 2015 | 06:33 PM
dawg's Avatar
dawg
https://www.hdforums.com/forum/touri...ml#post9530944
Old Nov 17, 2015 | 04:44 AM
roundy's Avatar
roundy
That post is a great repair, but as 69cj said, its the little pin that goes in the hole that the little spike clips into I need to replace.
I know it can't be purchased, so was wondering if anyone out there has managed to rig a repair.
SE120RG
Aug 2, 2023 10:42 PM
Jumpman
Aug 14, 2017 09:57 PM
Bill918
Mar 21, 2015 03:01 PM
VETERAN75
May 29, 2013 11:11 AM
