Is this normal?
Old Nov 21, 2015 | 02:43 PM
Stiggy's Avatar
Stiggy
We're all guessing here, but I'm guessing the forks.
Old Nov 21, 2015 | 03:05 PM
Campy Roadie's Avatar
Campy Roadie
Steering neck bearings are loose. I wouldn't ride it much until you adjust them. You'll beat the bearings into the cup. Those bad boys are loose enough to grease
Old Nov 21, 2015 | 03:39 PM
steelerdude1's Avatar
steelerdude1
I rode out to a dealership and had them check it out. Guess what they said. . . . . it's normal. I went into the shop and they showed me what is making the noise. it's coming from the floating rotors. We each held a rotor, and another mechanic rolled it back and forth like I did in the video, and you can feel it in the rotor.
They told me that mine is louder than any they have seen, but that it is safe, and not to worry about it. They let me roll a new one on the show room floor to hear that it does it as well, just not as loud.
Hopefully they are correct, I had the mechanic take it out for a road test and he felt confident that there is no issue.
Old Nov 21, 2015 | 03:47 PM
Lowcountry Joe's Avatar
Lowcountry Joe
I agree that this is likely the problem. Easy enough to fix yourself, but since it's a 2015, it's under warranty still. I agree also that you would be better served NOT to ride that bike until you get this issue solved.
Secondary thoughts are loose caliper bolts/loose pad pin bolts. Easy to check.
Other possibles: front axle nut loose or triple tree pinch bolts loose.
Old Nov 21, 2015 | 03:54 PM
Backforty's Avatar
Backforty
My 14 RK does it. Same sound. If you notice, it does it once going forward and won't do it again going forward until you've applied the brakes backing up.
Old Nov 21, 2015 | 04:05 PM
t. sawyer's Avatar
t. sawyer
Question
ok I know nothing about floating rotors, but that sound ...sounds like alot of slack somewhere. so my question is, why does it have slack or movement that seems to me can cause a great deal of wear over a short period of time.
kroozeabout.
Campy Roadie
You'll never know for sure til you put the bike in the air with the front wheel suspended and check the forks.
Old Nov 21, 2015 | 04:11 PM
Stiggy's Avatar
Stiggy
And the reason I suggested the forks is because it sounded like the clunk happened as the forks topped out. (A lot of suspicious minds in here!) Let us know if it gets any worse.
Old Nov 21, 2015 | 04:24 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
sloppy fit between the rotors and pins.
Old Nov 21, 2015 | 06:14 PM
skratch's Avatar
skratch
no grease fitting on a 2015. requires disassembly to service.
