Clutch Cable
Old Nov 22, 2015 | 10:54 AM
kryingame's Avatar
kryingame
Default Clutch Cable
I recently had 12" Yaffee bagger bars installed by a local shop.
Yesterday, I was at the dealership for something unrelated. The mechanic who was servicing my bike reported that the shop which installed the bars put a clutch cable in which is to short and that I need a new one which is 3-4" longer. The cable is $55 and it requires 2 hours of works.
I honestly can't imagine the dealership would lie. Why risk their reputation but while riding, the clutch feels fine. I know my dealership tends to fall on the conservative side.
Assuming that the cable is short (if the cable is to short, how can it even fully connect), what if any damage could it cause?
Thanks!
Old Nov 22, 2015 | 11:01 AM
tj316's Avatar
tj316
If the cable is to short it would bind when turning hard left , if it doesn't bind you are ok
Old Nov 22, 2015 | 11:09 AM
msocko3's Avatar
msocko3
They may have taken the too short of cable and changed the routing so it fit, its a redneck solution. The guy who said it needed a longer cable is in all likelihood right on the money.
Old Nov 22, 2015 | 11:20 AM
RANGER73's Avatar
RANGER73
Both these answers are right on the money.
Old Nov 22, 2015 | 11:58 AM
mkguitar's Avatar
mkguitar
so look at the routing- there are 2.5 potentials there which need to be avoided
1.) the cable hangs up and keeps you from moving the bars to point the bike (We had a post like that a few years ago- he crashed)
2.) the movement of the bars causes the clutch the disengage or slip
2.5) the routing causes stiction of the inner cable and it doesn't engage/disengage smooth
If this is true- Go back to the original shop and point out what could be an error.
tell them you'll pay for the new cable- but they should put it on at no charge....why, because you are coming back and the info you share is a help to them.
Rather than you being disappointed and sharing your experience with other riders
this will likely require the removal of part of the exhaust system, opening the trap door cover and attaching the new cable- that's what chews up the time.
mike
Old Nov 22, 2015 | 12:29 PM
kryingame's Avatar
kryingame
Thanks guys.
This is why I hate using small shops. They charge less up front but it'll always cost more in the long run because they always cut corners.
Old Nov 22, 2015 | 03:50 PM
msocko3's Avatar
msocko3
Originally Posted by kryingame
Thanks guys.
Before having a shop work on your bike, take advantage of the knowledge base on the forums. Ask the questions of folks here, this way you go in as an informed consumer. I know shoddy Harley Dealer mechanics hate the internet.
DanHappy
40
May 28, 2019 12:30 PM
gnalen
Jul 31, 2017 01:31 PM
traildog
EVO
Jan 8, 2013 07:53 AM
GregX999
May 2, 2012 11:56 AM
Chunker
Jul 13, 2011 10:12 AM
