Seat height
Old Nov 27, 2015 | 08:49 PM
harley0711's Avatar
harley0711
Originally Posted by vizcarmb
Dang, Im hella vertically challenged and like my stock Road King with the seat. Flat footing is a non issue for me since I can never get both feet on the ground. I just use one foot. I would recommend building your confidence in riding and knowing your surroundings and foot placement instead of worrying about having both feet in the ground. You will also build more leg muscles. I know it looks embarrassing getting up and walking your bike but my ego doesnt bruise very easily
Have you considered the more narrower primary cover? That might work
Learning how to stop and rest on Only one foot is only good IF that is the ONLY way you can ride... but to suggest to others to learn that - I disagree - by learning that - every time you stop - you lean to that one foot - again, IF that is the ONLY way you can ride -
Problem is IF that one foot Ever slips - well, you are leaning that way and it is so very easy to drop the bike - if at all possible - learning to stop with both feet on the ground - allows the bike to stop straight up and NOT leaning to one side -
Old Nov 30, 2015 | 11:33 AM
VETERAN75's Avatar
VETERAN75
Originally Posted by capjs
how much did you shave off of sides and seat? and did you have mcc do this?
I did it myself. Don't know how much total. Pretty easy just be careful the contour doesn't get messed up. Do a little bit and sit on it, do that till you happy. Watched a couple you tube videos too.
Old Nov 30, 2015 | 06:43 PM
farmboy555's Avatar
farmboy555
Mean City and a pair of logger boot's should have you sitting tall in the saddle 👍
Old Nov 30, 2015 | 07:11 PM
jimmy1439's Avatar
jimmy1439
Another vote for Mean City. I had the same problem and didn't like the one foot on the ground approach (yes, I tried). I'm 5'8" and had them take 1.5 inches out of mine and put some memory foam in it. It's the "Super Narrow Mod". They also narrow up the nose of the seat. Awesome folks to do business with and the modification made all the difference in the world for me. Much better option for me since I didn't want to buy a new seat unless it was necessary.
Edit: Most folks won't need that much taken out of the seat. I came off a lowered Heritage, so I like that to have my knees bent a lot.
Old Nov 30, 2015 | 07:22 PM
Bobwood's Avatar
Bobwood
2nd Gear
I'm also one of those vertically challenged folks and was on an '07 Ultra until recently. I lowered the back end and put the reach seat on it. Very happy with that set up and it rode great. I just bought a '15 Ultra low that I can almost flat foot right off the sales floor but was surprised to find out the rear shocks are those new reduced profile hand crank nitrogen shocks. Some folks like them but I like the air shocks so the minute I got it home, I took those off and put some low profile air shocks on the bike. The hand crank shocks now sit in the closet. I think I'm going to follow some of the suggestions and give Mean City a call.
Cheers
Bob
Old Nov 30, 2015 | 07:24 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
5'6" is meaningless. What's your inseam? That's what matters. There comes a point where it just can't be well done.
Old Dec 2, 2015 | 08:36 PM
C908's Avatar
C908
Ok maybe this will help since I'm 5'7 and I ride a 2010 Ultra. I will also add I have a 30' inseam. I started out with the stock low seat and I use a 1 inch Burley lowering kit with stock 13' shocks. I wasn't real pleased with the stock seat, personally I think they are junk. I ordered a C&C low profile seat with the riders backrest and the rear seat pad.This seat does sit me back 1 inch but it works perfect with my 12.5 Wild One Apes. My decision on C&C was based on their excellent reputation. I have been very pleased with the C&C and will definately buy from them again. I am able to flat foot without any problems. Hope my information was helpful.
Shortround
Sep 25, 2019 08:17 AM
bikermikee
Milwaukee Eight (M8)
Feb 21, 2018 11:30 PM
lucsvette
Canada
Jun 6, 2017 02:09 PM
Erilflynn
2014-2024 Touring Models
Jan 8, 2017 02:43 PM
HAWGMAN
Oct 26, 2015 09:04 PM
