Handlebar clamp question
Old Dec 6, 2015 | 12:12 PM
68 Shovelking's Avatar
68 Shovelking
Default Handlebar clamp question
I have narrowed my bar choices down to Carlini 1.5 Gangster or LA Chopper Tree Huggers, either would be 16" rise. Question I have is which system offers better clamping force, more rigidity, less bar movement, etc.
Old Dec 6, 2015 | 01:21 PM
decencyxdefied's Avatar
decencyxdefied
I have the stock riser, clamp,and Properly torqued with poly bushings with no issues
Old Dec 6, 2015 | 09:18 PM
crimson13's Avatar
crimson13
Imho the tree huggers ,they mount directly to the trees and once they are locked down that's it ,plus they are 1.5 and look great.had some on my rk comfortable bars
Old Dec 6, 2015 | 10:29 PM
68 Shovelking
Thanks. They look well made and well designed, not sure why I don't see more people running them.
Old Dec 6, 2015 | 10:43 PM
Buelligan666's Avatar
Buelligan666
Probably due to the fact you have no adjustment once mounted. Any bar that mounts in the clamp style riser can be pushed forward or pulled back to accommodate the rider. I have my WO577's pulled back about 3/4" from the Wild Ones "specs". It suits me, maybe a guy a little taller would push them forward almost touching his fairing. Something to consider.
Old Dec 6, 2015 | 11:05 PM
68 Shovelking
Tree Huggers can also be adjusted forward and back to suit rider. Look closer at how the mounting system works.
Old Dec 6, 2015 | 11:30 PM
Buelligan666
Noted. They looked like they were welded solid from the pictures I looked at. I'll have to check that out.
Rollcage
General Topics/Tech Tips
May 24, 2016 12:06 PM
bubdifab
Jun 20, 2012 07:24 AM
tmac
May 16, 2012 08:55 PM
MMCHD
Apr 27, 2012 06:26 PM
jmorganroadglide
Oct 20, 2011 08:30 PM
