Lowering kits and ground clearance
Old Dec 11, 2015 | 07:47 PM
Cozz's Avatar
Cozz
Default Lowering kits and ground clearance
Question for those of you that have lowered your rear 1 inch.
Have you had any problems with dragging floorboards in turns, or scraping on speed bumps or any other ground clearance issues ?
Old Dec 11, 2015 | 07:54 PM
mkguitar's Avatar
mkguitar
are you starting from a a 13" or 12" bike?
On my '95 FLHTC which came with 1" blocks from P/O, teh jiffy stand would hit on left hand turns- I removed them.
on my 09 FLHTC I was aware of the reduced clearance, some light contacts on turns floorboards ( which are made to swivel out of the way) and scrapes on speed bumps for sure.
I returned to stock height.
on a 2011 FLHTK lowered 1" front and rear I contacted the X cover on V&H power dual header hard enough to cause a slide
Mike
Old Dec 11, 2015 | 08:10 PM
Cozz's Avatar
Cozz
I have stock air shocks. 5 lbs. air . Never measured them. I figured they were 13".
Old Dec 11, 2015 | 08:42 PM
mkguitar's Avatar
mkguitar
most models have 13", the X models have 12"...like a streetglide flhX ...
mike
Old Dec 11, 2015 | 11:43 PM
bikerlaw's Avatar
bikerlaw
LOL, OK......
The stock air shocks are 12 3/4 inches. They always have been. The "lowered" air shocks are 12 inches. Your 2004 Ultra came from the factory with stock length air shocks, or the 12 3/4 inch'ers. If you install 1 inch blocks (as did I), you will be sitting at 11 3/4 inches from center of bolt to center of bolt, effectively. Yeah, you will be more prone to scraping in turns, and you definitely want to be careful going over the Walmart speed bumps. I can make it over "most" Walmart speedbumps, but sometimes I can feel the frame hitting. I just take it slow. As far as the floorboards, that's up to you. Under normal riding, I'm good to go. But if I try, I can scrape them.
Old Dec 12, 2015 | 03:02 AM
Guntoter's Avatar
Guntoter
Now that winter, sort of, has set in and riding is pretty much over for awhile, go here: http://bitchinbaggers.com/products/drop-shocks/
I highly recommend this process be used to lower the back end of your Touring Harley rather than the cheap brackets. Have had Bitchinbagger do 2 sets of shocks over the years and they come back better than before. Plus you can get them lowered to where YOU want them to be.
Old Dec 12, 2015 | 05:47 AM
grbrown's Avatar
grbrown
Cozz, there are generally two reasons for owners to want to lower their bike: either looks, or to reach the ground better. Does either of those match your wishes? We can help with other ways of achieving the latter.
Old Dec 12, 2015 | 06:40 AM
Cozz's Avatar
Cozz
Mostly for looks, although, when my feet are down it's a little uncomfortable on my thighs because my street glide seat is so wide. I would only use the LA Choppers 1" kit since it maintains the correct shock angle, and it looks very beefy. Just thought I would kill two birds.
Old Dec 12, 2015 | 06:51 AM
RKZen's Avatar
RKZen
I lowered my King for reach. I originally went with HD Profile Lows front and rear, which dropped it about an inch. I now have Ohlins on the rear and are 12 1/8 eye-to-eye. I also have 21" wheels, so the front is dropped another inch to compensate for the wheel size. I've ridden the Dragon this summer and other areas near there and scrapped the boards only once.
On your seat, you can send to Mean City Cycles and get it narrowed a bit.
Old Dec 12, 2015 | 07:57 AM
sr230mike's Avatar
sr230mike
08 ultra classic here I went from 13" to 12" it scrapes something on real hard turns but pretty rare. I go easy on speed bumps anyway. I am only 190 lbs. and like yours my tour pack is off. It just reminds me that It's a 800lb plus touring bike and maybe I should slow down a little. Maybe
