Headlamp Nacelle - Missing Bolt...i think?
Old Jan 7, 2016 | 12:49 PM
Don-T's Avatar
Don-T
Originally Posted by bornindadamnusa
The pictures I saw, or should I say picture, first one could not tell what I was looking at, show the headlight trim ring and has nothing to do with nacelle. Mine is not a lock nut at all but an elongated nut and like mkguitar said, about a quarter inch long, give or take.
According to my dealer that elongated nut is a lock nut. My headlight doesn't have one but my auxiliary lights both use them.
Old Jan 7, 2016 | 01:14 PM
roundy's Avatar
roundy
Awesome, thanks for the help guys, will try and find something to suit!
Old Jan 7, 2016 | 01:45 PM
mkguitar's Avatar
mkguitar
Originally Posted by Don-T
According to my dealer that elongated nut is a lock nut....
could be, but mine is not- if you look at earlier pic, you'll see traces of locktite on the threads of the machine screw.
a locking nut would need a nylon liner ( nylock), however nylocks do not tolerate torque- the nylon will just pull away from the steel, so not suitable in many applications.
There is also no mechanical locking mechanism attached the the nut- on my version of this- yours may be different.
Mike
Old Jan 7, 2016 | 02:37 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by roundy
Ahh yes, just looked at a picture of my front headlamp vs. the stock one and it's quite different!
Assume I am still looking for the #8 screw and nut though!
Your stock one is sitting under that trim ring. For fun, here's the installation instruction for the flat type, same as the visor style. http://www.harley-davidson.com/app-c...ts/-J01369.PDF
The oem nut, in the oem package, showing the M4-0.7 thread pitch.
It's a crude fitting and mount, almost anything will actually work.
Old Jan 8, 2016 | 04:10 AM
roundy's Avatar
roundy
Thanks for that info sheet and the picture, perfect! I shall see if my dealer has them in!
Old Jan 8, 2016 | 11:07 AM
Don-T's Avatar
Don-T
When you go buy the parts make sure you get a screw and nut that work together. The nut pictured above is metric and it looks different than the one sold to me. The one I have is a 8-32 screw and nut. The nut is longer and has more taper at the end of it.
As I noted above, the dealer called it a lock nut, but I am not sure it really is. As Mike noted it doesn't have a nylon insert and it doesn't appear to actually be a lock nut, just a long nut with a tapered end on it. I didn't try to thread the screw all the way through it when I verified they work together. When I installed it I could feel it pulling the trim ring tighter but again I couldn't say for sure that I could feel the extra torque a lock nut would require. I didn't Loctite mine, maybe I should take them apart and add the Loctite before I loose something.
Old Jan 8, 2016 | 01:52 PM
roundy's Avatar
roundy
Used the part numbers from the Harley instruction sheet for the trim ring, collected this evening from the dealer, perfect fit :-) Thanks for all the help guys, much appreciated!!
Lok Hang Yung
Jan 21, 2019 03:06 PM
Memo7070
Nov 21, 2014 08:06 AM
BuckeyeUltra
May 6, 2014 08:04 AM
jerryw618
Oct 29, 2012 10:19 AM
CSS_FXD
EVO
Feb 18, 2012 09:55 PM
