2016 Electra Glide ultra classic low
Old Jan 23, 2016 | 06:26 PM
Punjabi Rider's Avatar
Punjabi Rider
Also I would suggest using RSD adjustable clutch and brake levers to make it little easier to grab hold of the clutch lever, since you might have difficulty with the stock hydraulic clutch.
Old Jan 23, 2016 | 06:44 PM
manofire12's Avatar
manofire12
6th Gear
Thanks. I will look at that one also.
Old Jan 26, 2016 | 11:54 AM
Ultraboy105's Avatar
Ultraboy105
It's all about your inseam. If your height is 6'3" but your inseam is 28" you're probably going to need a low. Assuming you're at a 32" you might not enjoy having your legs in the position a "low" would put you in for any distance. I think the difference on a '16 would be grips seat and shocks. If you bought a regular and bought the lower sgs/rgs suspension everyone is getting rid of, and the seat it would feel the same.
Old Jan 26, 2016 | 12:01 PM
manofire12's Avatar
manofire12
6th Gear
Originally Posted by ZenGlide
At 6ft 3in, I think a standard height EG would be better for you. No need to make concessions on suspension unless you really need it. I'm 5' 10" and considered a low, but I would need a standard seat on it. I can't imagine your frame size on the reduced reach seat. Have you tried a standard height EG?
I did sit on a used EG, it was comfortable. Just the new one(low) has all the bells and whistles and some things are standard on the low where as cost extra on other bikes. I was told to get a standard seat for it, that it would be a little higher, and set back a little further. But that comes from a salesman, that's why I came on here, to ask the riders.
Old Jan 26, 2016 | 12:09 PM
Markymannn's Avatar
Markymannn
You get a better ride with the standard EG or Ultra. Anything on the Low will be standard equipment on the regular EGlides too
Old Jan 26, 2016 | 12:20 PM
lmar's Avatar
lmar
I am 5'11" and I purchased a standard 2016 LTD. Fits me perfectly.
SluggoMagoo
Nov 30, 2018 10:59 AM
tidwelfern
2014-2024 Touring Models
22
Jan 5, 2018 10:40 PM
Who Dey
Apr 15, 2015 08:49 PM
mmcbeat
Aug 23, 2014 01:39 PM
Marty 124
Jan 13, 2009 08:58 PM
