Loctite Advice Please
Old Feb 9, 2016 | 03:23 PM
Rickr01's Avatar
Rickr01
Originally Posted by Carter Stindberg
Blue?... maybe.
The company itself tends to suggest types of Loctite to use based more on the size of the bolt itself rather than strictly on whether you will "ever" remove the bolt at some point or not.
Still, even after noting bolt size vs. Loctite type, there are other factors to consider such as long term vibration, heat, etc.
Just to add to the mix, this comes directly from a Loctite PDF on the use of their products. I bolded the relevant text myself:
"The strength and viscosity of the adhesive needed for an application are directly related to the size of the fastener used. Low strength threadlockers are used on screws up to ź-inch in diameter, such as adjustment and calibration screws, meters, gauges, and other fasteners that will need ongoing adjustment. Medium strength materials are for fasteners up to ž inch in diameter used in machine tools and presses, pumps, compressors, and as mounting bolts. High strength threadlockers are best used on fasteners up to one inch in diameter found in permanent assembly applications such as heavy equipment and a variety of mounts. Low viscosity penetrating threadlocking formulations are also available that easily wick into pre-assembled fasteners up to ˝ inch in diameter."
Thanks Again! Blue it is...
Old Feb 9, 2016 | 03:53 PM
LQQK_OUT's Avatar
LQQK_OUT
Lot's of good information in the "Do It Right" Guide provided by Henkel.
http://na.henkel-adhesives.com/us/co...t_Guide_v7.pdf
Threadlocking User's Guide
http://www.na.henkel-adhesives.com/u...de_v6_F_LR.pdf
Dieselvol
Feb 3, 2015 08:12 AM
Thumper09
Jul 10, 2014 07:05 AM
springer 03
Nov 10, 2011 10:00 PM
Jaymac3772
Oct 10, 2010 12:26 PM
kingofsand21
Mar 11, 2010 10:06 AM
