LOL, guess my description is REAL hazy. I tried to post a pic but no luck, that is hazy too
It is the shaft that the toe heel shifter levers attached too, so it is on the front of the assembly for shifting gears. The shaft allows two shift levers to attach to it. There is a bushing that goes on the shaft as well. The shaft goes through the front of the inner primary and that is where it attaches to the linkage that goes back to the tranny. Wish I could post a pic
So #15 then. Like others have said you don't have to pull the primary to replace it.
NO ... YOU DO NOT HAVE TO REMOVE THE PRIMARY. Remove the pinch bolt in #16 and work the lever loose then "pull the shaft (#15 ) out. Generally you won't need to replace the bushing that it rides on. Fit the new #15 into the case and check for "excessive slop". If it feels good re-assemble the levers and ride.
