Grounding Lug?
Old Feb 29, 2016 | 08:16 AM
Talldog's Avatar
Talldog
Default Grounding Lug?
I've got too much crap connected directly to the battery.
I've got the Harley connector so I can "Daisy Chain" some stuff to the B+ Connector, but that's only the Hot side.
What have you guys done for the Neg side...thinking some sort of Grounding Lug?
Old Feb 29, 2016 | 08:41 AM
leon anthony's Avatar
leon anthony
where did you get the Harley Connedtor and is there a part number I would like to have one
Thanks Talldog
Old Feb 29, 2016 | 09:19 AM
Talldog's Avatar
Talldog
Thanks Talldog
Leon,
Part # 70270-04A (for up to a '13 Touring model).
Page 413 in the 2016 P & A book.
Old Mar 1, 2016 | 04:38 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Default Just a thought of where to tap Bat+
I made a two wire adapter that fits firmly into the MAXI fuse socket using the male/blade contacts of an H4 headlight cable extension kit. You can connect your own circuit splitter from here and keep the functionality of the 40A fuse.
Old Mar 1, 2016 | 07:18 AM
nhrider1's Avatar
nhrider1
Any solid ground works fine for the negative side of the battery. The battery negative is grounded to the frame...so a lug mounted solidly to anywhere on the frame works fine.
Old Mar 1, 2016 | 01:07 PM
btsom's Avatar
btsom
The Harley connector itself won't care to which battery terminal it is connected. If you don't want to drill and tap for a frame lug just use another Harley connector on the negative terminal.
Old Mar 2, 2016 | 01:27 PM
Talldog's Avatar
Talldog
For anyone thinking of doing the same, think I'm gonna give this a try.
http://www.jlaudio.com/xb-mglu-car-a...ound-lug-91658
Old Mar 2, 2016 | 01:37 PM
chamokie's Avatar
chamokie
#1, should work just fine
eki912
May 30, 2016 12:26 PM
bmfakler
Ironhead
Aug 4, 2015 09:17 PM
RPG485
Jul 7, 2014 03:53 PM
hutch08
May 28, 2014 09:51 PM
scott
Oct 18, 2005 10:57 PM
