dyno tune results
Old Mar 2, 2016 | 06:38 PM
jt metal's Avatar
jt metal
Originally Posted by liquidr1
just an observation, but it looks like the dip in torque happens just as there is a dip (richening in A/F) just at 2700 rpm. Doubt its clutch slip. It dips all the way down to 10:1 A/F. That seems way to rich to make any power at that low of an rpm.
Saw that as well. I'm thinking that is the dreaded "crosstalk" or "reversion" that they talk about.
The more I look at it, The torque band is pretty flat. Hope added a 2/1 will just enhance the band and not alter it.
I'll get some feedback from a few of the vendors down in Daytona.
Time to pick some brains!!!!! Lol, my favorite part.
Old Mar 5, 2016 | 02:17 PM
jt metal's Avatar
jt metal
Well. Put some miles on the new combo. Much better with dynotune and head.
Bike flat out rocks! Once the power starts, carries all the way thru to the next shift.
I'm happy!
Old Mar 5, 2016 | 03:59 PM
firefighter156's Avatar
firefighter156
The HP/TQ isn't terrible. BUT, with head work you should have more HP than the end result. The dip in the Dyno sheet is brutal. Could be reversion? Something isn't playing nice together. Head work maybe should have been with the 777 vs the 555?? Mufflers are not helping you at all. Who tuned it? What tuning device PV, HD, TTS??
Old Mar 6, 2016 | 06:44 AM
jt metal's Avatar
jt metal
Originally Posted by Localprez
Something isn't playing nice together. Head work maybe should have been with the 777 vs the 555?? Mufflers are not helping you at all. What tuning device PV, HD, TTS??
Yes, to all of the above. Hahah. To much head for 555. Mufflers blow! But bike is awesome. Using a powervison tuner.
The real answer to this is probably, should have a better cam, better exhaust, and a better tuning device. Open loop/ closed loop. Lol! Something.
Maybe I'll save it for next time. Once I get bored. We all know how that goes.
Old Mar 6, 2016 | 06:45 AM
firefighter156
Compression set at 10.6
Rush Wrath with 2.55 baffle
Stock 103 pistons and cylinde
TW 777 Cams
SE 10.5 +.010 Pistons, Ward CNC port stock CVO heads-stock valve size, D&D 2-1 w. 2.5 perforated baffle, SE 58 TB SE 5.32 Injectors, SE Heavy Breather, T-Man 590 Chain drive cams,
Perhaps this is what you were after?
Old Mar 6, 2016 | 12:45 PM
Cliff R's Avatar
Cliff R
What we look for with these engines, a broad/flat power curve (torque) will be more user friendly day in and day out that a butt-load or top end HP and "soggy" down low.
Here's a sheet from my 02 CVO Roadking, it's got CNC ported SE heads and pretty "hefty" cams in it, 2 into 1 exhaust. The way it makes power it just pulls HARD everyplace, no big "rush" of power anywhere in the rpm range and no "lag" anyplace either. For some reason the curves are shifted to the right on the graph, it should cross at 5250rpm's, and no way they pulled it out to past 9000rpms, but at least you can get an idea of how flat the torque curve is.
I'd rather have this sort of power than some big upper mid-range and top end number on a dyno sheet simply for bragging rights.....FWIW......Cliff
Old Mar 6, 2016 | 03:23 PM
firefighter156
But the HP doesn't cross the 100 mark until 3000 and flattens/ends at 4000??
Old Mar 6, 2016 | 03:44 PM
77Tulsa's Avatar
77Tulsa
[QUOTE=Localprez;14912957]But the HP doesn't cross the 100 mark until 3000 and flattens/ends at 4000??[
That's the torque.
Old Mar 6, 2016 | 05:43 PM
Jaystn62's Avatar
Jaystn62
JT did you get the Crushers? I'm loving mine so far. Hopefully get tuned this spring.
Old Mar 6, 2016 | 07:31 PM
jt metal's Avatar
jt metal
Not just yet. I need to know what will help the most, with that low spot in power. Do I need to step into a 2 into 1????
