Roadking throttle cable install?
Old Mar 12, 2016 | 07:36 PM
Ndoggct's Avatar
Ndoggct
Default Roadking throttle cable install?
Has anyone gotten thus done without removing tank as it is called for in the manual on a 07 roadking?thx!!
Old Mar 12, 2016 | 08:12 PM
BackRoader's Avatar
BackRoader
Have not done it myself, but have heard of people just loosening the tank and using the old cables to install new ones. Just tape the new cables on to the ends of the old ones and pull em through. Sounds simple enough...Good luck.
Old Mar 12, 2016 | 08:39 PM
skydude426's Avatar
skydude426
Unbolt the tank and stick a wood block under the front on top of the frame too hold it up an inch or two higher, basically as far as the fuel crossover will allow. This will give you a little more working room. I've replaced the throttle and idler cables this way, no problem.
Old Mar 12, 2016 | 09:28 PM
Munkee's Avatar
Munkee
Yup i did it in my 07 SG without so much as touching the tank.
Old Mar 13, 2016 | 09:53 AM
Ndoggct's Avatar
Ndoggct
was going to attempt to attatch new cable to old and fish it through once i get the new ones, but who knows if it will work..thx guys
TylerBoehm
Jun 7, 2014 06:55 AM
ChromeJunkie
Aug 5, 2009 09:44 AM
roofer
Nov 15, 2007 11:32 AM
bpdeepwater
Sep 2, 2007 06:51 AM
KBES BAGGER
Jan 28, 2006 01:20 PM
