stock pushrods with SE 204's
Old Mar 20, 2016 | 06:31 PM
roussfam's Avatar
roussfam
Stock pushrods are free and I've found easier. Adjustable' s were a pita to set up. Just my experience. No biggie pulling your rocker boxes plus you get to refresh your breathers, enlarge the oil drain holes and install rocker lockers at the same time. Six of one, half a dozen of the other....personal choice
Old Mar 20, 2016 | 06:45 PM
RevBlk's Avatar
RevBlk
I'm putting in S&S 551 Easy Start cams in mine a re-using my stock pushrods because it's cheaper. I want to open up my drain holes and change/update my breathers anyway. I could be wrong but any hp or torque left behind would be minimal. If I'm wrong its an easy switch to adjustable pushrods later. Just my .02.
Old Mar 20, 2016 | 07:11 PM
jammerx's Avatar
jammerx
1.725:1 rocker arms
Old Mar 21, 2016 | 08:15 PM
TSD's Avatar
TSD
Originally Posted by jammerx
1.725:1 rocker arms
Where do I get these rocker arms?
Old Mar 21, 2016 | 08:34 PM
rdc401's Avatar
rdc401
Se catalog not the rollers just the regular ones
Old Mar 22, 2016 | 06:18 AM
todd-67's Avatar
todd-67
Originally Posted by jimmything
Any one swapped out their cams for the Screaming Eagle 204's and used their stock pushrods. I don't want to go the adjustable route, and have no problems with the extra work taking off tank, rocker covers, asmbly, etc. I've heard you need after market pushrods that are different length. Thanks for any input.
The base circle of the cams are the same so you can re-use the stockers but as Joe mentioned there are other additional reasons for changing them out.
Old Mar 22, 2016 | 06:34 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The 1.725's will effectively create another .030" lift, and 2-3 degrees more duration.
We keep those on deck here in our inventory to use as we need.
Scott
PeterV
Engine Mechanical Topics
Aug 8, 2016 09:50 PM
ThisIsMe
Sep 22, 2014 10:49 PM
UFO8MyCow
Aug 27, 2013 02:35 AM
2009blackpearle
May 9, 2012 02:26 PM
SecondChance!!
Apr 20, 2011 06:01 PM
