quick fullsac question
Old May 15, 2007 | 04:37 PM
bulldogmoe7's Avatar
bulldogmoe7
Default quick fullsac question
just have an easy question. i just ordered the fullsac duels this morning. i know on the right side the shields are not going to match. i dont like the idea of how it will look with the existing heat shield turned around 180 deg. i need to know the length of the this gap so i can order the new piece and have a solid heat shield. i am keeping all of the other heat shield. looking fo for the measurement from the timing cover to the begining of the pipe. if i need 2 peices that will befine.
i would measure mine but it is in the shop for a couple of more days.
Old May 15, 2007 | 04:58 PM
lschultz's Avatar
lschultz
Default RE: quick fullsac question
I ain't no help cause I am at work and mine is at home.
Old May 15, 2007 | 05:57 PM
Dogwood's Avatar
Dogwood
There will not be a "gap" between the 2 heat shield.
There's a visible line where they meet, and the cut-outs at the front and rear points are hardly noticable.
Old May 15, 2007 | 06:47 PM
Mick's Avatar
Mick
You might want to try them the way fullsac suggests first.
I was telling the owner of an independent (Harley only) shop about the conversion and he wanted to see them.
I went over , and he looked at them and said "pretty cool" and it wasn't until I showed him what I did with the factory shields , that he even noticed.
He may get a set after seeing mine for his new Road Glide.
It's hardly noticeable.
Mick
Old May 15, 2007 | 07:07 PM
FLHT's Avatar
FLHT
ORIGINAL: myride85
OK here is what I did at it looks great I think. Front heat shield I bought of of e-bay, the place always has them on there. Here is the link.
http://cgi.ebay.com/ebaymotors/Exten...19687502QQrdZ1
The next piece back you use your stock heatshield, but you will need to cut off a little of the curved end towards the back. Next piece I bought a 12 inch section from JP. Here is the link for it.
http://www.jpcycles.com/productgroup...=Harley&page=1
I wasnt able to find one piece to run the full lenght. This is the end product.
Old Dec 18, 2008 | 10:01 AM
edman48's Avatar
edman48
Default Re: Fullsac Question/Heat Shields
Hello: I just installed the Fullsac conversion on my 2006 Road Glide and is sure makes a difference! Also, I have the V&H basic slipons and Fuelpak. I am using map no. FP-0146. The RG seems to run stronger and really sounds great. Fuel mileage seems to be the same. Also, there is a decrease in heat on both sides for the rider and passenger. I reversed the heat shields per Fullsac's recommendation and they look ok. But, I would like to find replacement heat shields. Does anyone know where to find them and what their size should be? Any info would be greatly appreciated!
Regards,
Edman
Virginia Beach, VA
2003 V-Rod (sold, but still loved)
2006 Road Glide
Old Dec 18, 2008 | 11:08 AM
wkenddad's Avatar
wkenddad
I used to have a full sac...
But since the combine accident they call me one nut...
So, I don't have a full sac anymore.....
Old Dec 18, 2008 | 03:31 PM
confused's Avatar
confused
FullSac here
Ordered the J&P 18" shields
Had to cut it some but it runs the full lenghth of the exhaust
still have the "line" in the middle, but I am
very happy with the results
Old Dec 18, 2008 | 04:06 PM
harleyflo's Avatar
harleyflo
i didnt like the look of it so i just got a y pipe and cut off the left side ,caped it off,and now it looks like stock but its a real true dual.
Old Dec 18, 2008 | 04:18 PM
garyhendley's Avatar
garyhendley
yep i used a 18" flamed sheild to cover the gap-ride safe
VGNKNG
Aug 3, 2015 02:29 PM
Loc_Tite
Aug 6, 2013 07:25 AM
ilmanzo31
Exhaust System Topics
Feb 2, 2010 10:39 PM
capt945
Aug 16, 2007 07:52 PM
RoadKing06
May 21, 2007 06:09 PM
