HELP. Fork lock won't disengage
Old Mar 28, 2016 | 05:58 PM
Papa Joe's Avatar
Papa Joe
Default HELP. Fork lock won't disengage
I have a 2015 road glide. I have the bars and controls removed, because I am changing them out. When I was removing the stock clamp/risers, the wheel turned fully left, and the forks locked. Now I can't get them to disengage. Any ideas? Appreciate the help guys.
Old Mar 28, 2016 | 06:01 PM
mkguitar's Avatar
mkguitar
youtube will show how to make a tool to align the cams in the lock from a piece of squashed copper 1/4" tubing.
this is best used to keep cams aligned as soon as the lock is removed.
you can use a screwdriver to move 1 cam at a time...when you get it all together- check very carefully that each switch function and the lock works as designed
mike
Old Mar 28, 2016 | 06:10 PM
qtrracer's Avatar
qtrracer
Turn the bars fully left to relieve the pressure on the lock while turning the key. If I read you right, if I don't, sorry, carry on.
Old Mar 28, 2016 | 06:12 PM
Hate Work's Avatar
Hate Work
Get a flashlight. Look down the ignition tumbler shaft. When you pulled the ignition out, all the tumblers were aligned. My "notch" was at approximately 8 o'clock. If that doesn't work, spend the little money on an alignment tool. Good luck.
Old Mar 28, 2016 | 08:10 PM
EasternSP's Avatar
EasternSP
I screwed up my alignment so many times while working on the bike so I bought the tool. Now it takes just a moment to correct it.
Old Mar 28, 2016 | 08:26 PM
Guntoter's Avatar
Guntoter
http://www.marcparnes.com/HarleyIgnitionSwitchTool.htm
Aircrew9
General Topics/Tech Tips
Jan 14, 2018 09:35 AM
johnod
EVO
Sep 4, 2014 09:44 AM
captjwteal
Aug 15, 2012 03:43 PM
streetglide13
Feb 10, 2009 05:41 PM
Lawdawg
Jul 25, 2006 10:51 PM
