I see no reason to add 3/4 of a pound of unsprung weight to a wheel that takes 7/8 of an ounce of weights to balance.
You can feel the balancing media shifting during rapid direction transitions.
If your wheel has a lateral balance imperfection the liquid does nothing to fix it.
There's debate as to tire integrity after a puncture. I''ll ride a plugged tire, I'll even ride one with 2 even 3 plugs spaced far enough apart but I want to know how many punctures I have in the tire and make an informed decision.
I change my own tires, the worst wheel tire combo I ever had to mess with took 1.5oz of weight, that was a friends GSX-R with a lateral imbalance to the wheel so you had to balance both one side was about 30 degrees offset from the other. His bike was always fun to change tires on.
In my toolkit I have stuff to plug a hole in tire and also have the small Harley air compressor on board. If I can't fix it, I'll call for road service! I always keep check of my tires, looking for wear and making sure pressure if OK frequently. Nothing can ruin your day like a flat tire!
