Security Key Light acting weird - DTC codes???
Old May 15, 2007 | 09:36 PM
dchoran's Avatar
dchoran
Default Security Key Light acting weird - DTC codes???
You know that little red key/light on your speedo that blinks on and off everysecond or so when you set your FOB???
Well mine is doing something real funky - blinks every second or so but then every few minutes it has a spasm and blinks like 3 or more times in a split second. Looks bizarre.
Any significance to that???
Maybe the bulb is about to go on the "blink"???
I know, it is a dinky item, but I just spent quite a few bucks on the Security II system with Pager and am wondering if that changed something???
THANKS.
Old May 15, 2007 | 09:40 PM
Hombre's Avatar
Hombre
Default RE: Security Key Light acting weird???
Sounds like the ECM threw a code. Is it running OK? I had that once (stayed on solid) and it was a short.
Old May 16, 2007 | 08:59 AM
dchoran's Avatar
dchoran
Everything is normal.
Old May 16, 2007 | 09:53 AM
1of2's Avatar
1of2
"Moderator"
It is telling you to check for a code. Look in your manual and see how to do a diagnostic check. It will tell you what happened.
Old May 17, 2007 | 07:45 PM
dchoran's Avatar
dchoran
I have the owners manual AND the service manual for the '05 Ultra.
Neither have a section on diagnostic codes???
Old May 17, 2007 | 07:55 PM
voodoodrug's Avatar
voodoodrug
I think you need elect diagnostic manual? maybe some one can scan and post?
Old May 17, 2007 | 08:36 PM
dchoran's Avatar
dchoran
Default RE: Security Key Light acting weird - DTC codes???
OK I found the DTC procedure in the DIY section of the forum. Cool - did it.
Results: P = nonE S = nonE SP = nonE T = nonE
After the "nonE" shows up and I press the button again, in each section, I get a "code" but it looks more like a part number in this format Pn 12345-06.
Called the dealer - typical BS - even though I just bought the 5 year extended service plan - all they said was reset it - so I ask how - and they say read the owners manual - thanks, that was real helpful - NOT!!!!!!!!!!!!!!!! Not even the $50 service manual talks about DTC.
Maybe I should have taken those funds towards the extended warrantee and paid people here on this forum instead for more valuable advice!!!!!
I am thinking I'm OK and maybe just have a spastic security key light.
Mr_Bill
Electrical/Lighting/Alarm
Apr 24, 2022 10:06 AM
j09789
Jun 16, 2020 04:48 PM
rich1374670x
Oct 1, 2013 11:50 AM
lowflyer
Jul 6, 2011 10:57 AM
pipefitter537
May 23, 2005 12:18 AM
