oil and tranny O ring?
Old May 17, 2007 | 12:59 AM
harleyrobert4's Avatar
harleyrobert4
Default oil and tranny O ring?
Beside Harley or any other cycle shop, where can I get a supply of the little rubberO rings that go around the oil and tranny drain plugs. Can they be purchased at Lowes or Home Depot?
Old May 17, 2007 | 01:02 AM
Bryan1724's Avatar
Bryan1724
Default RE: oil and tranny O ring?
Yes, also at True Value and such. I have a bag of 100 from McMaster Carr. Probably not exactly the same but they work fine. I put a new one on every oil and trannychange.
Old May 17, 2007 | 01:05 AM
harleyrobert4
Thank you.
Old May 17, 2007 | 01:19 AM
Grover's Avatar
Grover
Administrator Emeritus
Be sure to get Nitrile O-Rings.
Some rubber compounds do not stand up to heat and hydrocarbons as well.
Old May 17, 2007 | 01:47 AM
gman's Avatar
gman
gotta size for them?
[IMG]local://upfiles/12616/1C2B4BA0E3344D9196A7BFAFB0304D5B.jpg[/IMG]
[IMG]local://upfiles/12616/37244D3CBB9B416CBFD756729BFC3D74.jpg[/IMG]
Old May 17, 2007 | 02:00 AM
Grover's Avatar
Grover
I am on duty at the fire station until 0800 tomorrow.
I will check when I get home and post a part number for each.
Old May 17, 2007 | 02:02 AM
Bryan1724's Avatar
Bryan1724
These are what i use. Never had one leak yet, YMMV. [&:]McMaster Carr #9396K24 These are the silicon o-rings.
**Moderator Edit- Link Removed**
Old May 17, 2007 | 02:24 AM
oldfartjc's Avatar
oldfartjc
At $.25 cents apiece at HD why bother with anything but the correct o-ring.
Old May 17, 2007 | 02:30 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: oldfartjc
$.17 at Zanotti's I just happened to have a bag of 100 from McMaster C laying around, figured i would either usse them or throw them away. I'm using them.
Old May 17, 2007 | 10:35 AM
jbhawley's Avatar
jbhawley
an o-ring is an o-ring. HD doesnt 'make' a special size just for them. Most harware stores will carry them and probably all auto parts stores (napa, car quest, etc). I would suggest getting a new one of each from HD...then going to the auto parts store and find the correct size. Write that size in your service manual and then you can buy them by the gross if you want too. But at a quarter a peice, it is worth changing them at each oil change.
