Oil pressure bouncing around?
Old Apr 27, 2016 | 05:39 PM
blackflame's Avatar
blackflame
Default Oil pressure bouncing around?
My oil pressure is bouncing around. Used to be normal 32ish until hot. now it idles around 20-25 but will jump up to around 40-45 then drop back down with no load, it is not dropping to 0 and no lights are coming on. Just started lastweek. It's going in for cams and hydraulic cam plate and oil pump next week, but would like to ride this weekend. Any ideas?
Thanks
Old Apr 27, 2016 | 05:43 PM
voodoodrug's Avatar
voodoodrug
that sounds normal.
I added a higher strength relief valve spring and mine is always at 55 and never moves !!?&%$?
Old Apr 27, 2016 | 05:45 PM
blackflame's Avatar
blackflame
Originally Posted by voodoodrug
that sounds normal.
It never happen to my bike until last week. Trying to figure out what caused it to change?
Old Apr 27, 2016 | 07:31 PM
xcbullet's Avatar
xcbullet
Filter bypass maybe. Whens the last change.
Old Apr 27, 2016 | 08:03 PM
blackflame's Avatar
blackflame
Just changed it today, but didn't fix it. Same fluctuation.
Old Apr 27, 2016 | 08:58 PM
ses's Avatar
ses
I would be leaning toward a faulty gauge or sending unit. The only way to know is to hook up a manual gauge to test the oil pressure.
Old Apr 27, 2016 | 09:38 PM
InthewindMN's Avatar
InthewindMN
My guess if either a faulty guage sending unit or a sticky bypass valve in the pump. I don't think the extra pressure will hurt anything but you could call your mechanic for advice.
Old Apr 28, 2016 | 09:16 AM
RG Pilot's Avatar
RG Pilot
Why the need for such high oil pressure on these motors? They use roller bearings and not your typical main or rod bearings so high oil pressure isn't needed to fill bearing clearances and with too high of oil pressure, you'll fill the top of the motor too quickly. Just curious.
Old Apr 28, 2016 | 09:48 AM
lp's Avatar
lp
Rods on piston side, lifters, rocker arms, cam to cam plate, crank on cam plate, etc are not roller bearings.
You also want good pressure for the jets to spray oil on the bottom of the pistons for cooling.
I imagine it would take 900 pounds (made up) of pressure to fill the top of the motor considering only ounces only make it up there under normal operation. Literally dripping out.
Old Apr 28, 2016 | 11:05 AM
RG Pilot's Avatar
RG Pilot
I was referring only to the lower end using roller bearings. There and cam bearings is where higher oil pressure is mostly needed in non roller motors. I was just curious because I was always an oil pressure guy while playing with V8's back in the day. I heard these motors don't need much pressure at all.
