PCIII Throttle Question
Old May 17, 2007 | 11:41 PM
ezlife's Avatar
ezlife
Default PCIII Throttle Question
Been playing with setting different closed throttle positions to see affects, as well as playing with the settings for the accel pump feature. See definite response difference after enabling the accel pump.
Question - After all this, now when I start the PCIII map software, connected to PCIII on running bike,all I get is dashes across the "% throttle" display, where it use to read zero after setting the throttle. Also, if I select set throttle position from the tools menu, it shows the closed setting I made, but the "current" window reads "0" where it use to fluctuate around closed setting number.
Tried resetting, unplugging, restarting, etc. What gives? Should I care?
Help...I'm a welder, not Geek Squad!
Thanks guys
Old May 18, 2007 | 01:08 AM
Taterdog's Avatar
Taterdog
Default RE: PCIII Throttle Question
I've seen dashes in the throttle position, but only when the PCIII wasn't communicating with my laptop or when it wasn't powered up. I assume you're seeing the serial number and map, so assume you're communicating. You might want to contact Jamie if you bought it from him, or Dynojet tech support to get some help.
VTwin-Goodies
Jun 26, 2009 12:00 PM
SC-Longhair
Jul 4, 2008 05:42 PM
swipter
Jan 2, 2008 01:23 PM
tom134
11
Nov 17, 2007 11:38 AM
HarleyWood
Exhaust System Topics
Jan 2, 2007 03:10 AM
