over torqued exhaust nuts
Old May 12, 2016 | 09:29 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
Default over torqued exhaust nuts
I think i may have over torqued the exhaust nuts when installing my head pipe. I may have over torqued 30 inch lbs or so, 150 instead of 120. I thought i had my torque wrench set to 120 but i looked at it later and it was set to 145 inch lbs. Could this be a problem with the exhaust studs or the retaining clips?
Old May 12, 2016 | 09:31 PM
QC's Avatar
QC
Probably not.
Old May 12, 2016 | 09:47 PM
decencyxdefied's Avatar
decencyxdefied
They may lose up after a few heat cycles. Check them again in a few days.. The stud may back out also if you dnt mess with them for awhile but that another easy fix
Old May 12, 2016 | 09:49 PM
Gitarded's Avatar
Gitarded
I've never seen a HD tech use a torque wrench... don't sweat it as long as they are even.
Old May 12, 2016 | 09:51 PM
dontdropit's Avatar
dontdropit
It was after a heat cycle that i over torqued.
Old May 12, 2016 | 09:52 PM
E8USMCRET's Avatar
E8USMCRET
My Indie has been wrenching on bikes full time since 1972 and I've never seen him use a torque wrench on stuff like that.
Old May 12, 2016 | 09:59 PM
QC's Avatar
QC
I can only get a torque wrench on three of them anyway, so I just use elbow torque.
Old May 12, 2016 | 11:07 PM
Guntoter's Avatar
Guntoter
There is zero reason to use a torque wrench on exhaust nuts, just use a 1/4" drive ratchet with a long extension and 1/2" socket. No way you can over torque them. Re-check a few times after hot and then cooled off and good to go.
By the way, 145 inch instead of 120 inch is no problem.
Old May 13, 2016 | 01:58 AM
tfi racing's Avatar
tfi racing
That extra torque has surely distorted the exhaust valve seats and the only options are trade it in immediately or drive the **** out of it for many more thousands of miles without a worry...
Old May 13, 2016 | 05:18 AM
skydude426's Avatar
skydude426
That isn't very much. I would think you'll be fine.
