S/E air cleaner without any other upgrades
Old May 19, 2007 | 01:04 AM
hogdad's Avatar
hogdad
Default S/E air cleaner without any other upgrades
Can you put the S/e air cleaner on without pipes, slip ons or a tuner?? I have the air cleaner and am waiting for the rest of the stuff to arrive and was just wondering?? 05 Lectra Glide Classic, 1080 miles tonight
Old May 19, 2007 | 02:05 AM
gman's Avatar
gman
Default RE: S/E air cleaner without any other upgrades
you will likely lean it out using that high flow AC. if it has a carb, you will likely have to re-jet. if EFI you will need a tuner (SERT, PC, etc.) to richen the AFR.
[IMG]local://upfiles/12616/3F9B218429E64337A812202E859A32A5.jpg[/IMG]
[IMG]local://upfiles/12616/516AF554226F481EBFF952E8AD135BA6.jpg[/IMG]
Old May 19, 2007 | 08:05 AM
serverpimp's Avatar
serverpimp
ORIGINAL: hogdad
I was in the same situation, time to kill, S/E AC on the work bench, and still waiting on slip ons to arrive. I decided I wasn't going to install it and get into a half-baked scenario. My pipes have arrived and now I have a different scenario that is making me wait on completing the install. [&o] It will all work out in the end and I'm just going to have to show some patience. I would suggest the same to you. Probably not what you wanted to hear. [sm=proof.gif]
Old May 19, 2007 | 10:48 AM
choochoo's Avatar
choochoo
Get the HD parts and accessories catalog 2007.
On page 539 (I think) is the air cleaner and a note of what
HD says you need to do.
It says an ECM reflash with the STAGE ! download is required.
But you don't need to buy the sert or pciii etc if you don't want to.
the sert , pciii etc are more adjustable and tuneable but not a necessity.
Old May 20, 2007 | 09:00 AM
Pastor John's Avatar
Pastor John
Good advice from everyone... I have tried the Stage 1 Air Intake without the download and the pipes got so hot I could smell them while on the road! I have even tried the stock housing and just a K&N Air Filter with the same results. The stock setup is running so lean that any additional airflow will produce a dangerously lean condition. Better to go with the download or aftermarket ECM tuner to avoid problems.
Old May 20, 2007 | 11:20 AM
hogdad's Avatar
hogdad
Yeah I guess I'll just wait it out. I'm still having a ball riding this bike and after almost 1 week of ownershipI really don't miss my Sportster at all-even with all the speed and obnoxious outlaw biker sound it had from the drag pipes. After 10000 miles of on the edge riding with my 05 1200 CustomI was overdue to screw up.The radio/CD on the Electra Glideis veryenjoyable. The looks from motorists when I'm stopped at a light or tooling alongfeel pretty good too. Especially the older guys-the vets from the military and the motorcyclist vets,you could just tell.
nashvegasmatt
May 31, 2014 03:48 PM
Wranglin4Life
Sep 9, 2013 09:35 PM
freebyrd
Jun 8, 2008 12:12 PM
Cage996
Apr 20, 2007 10:38 AM
NEONNIGHT34609
Aug 4, 2006 04:43 PM
