stalling at stop
Old Jun 30, 2016 | 11:26 PM
  #31
Zerk's Avatar
Zerk
Why do you think this is unique to FLHs?
Old Jul 1, 2016 | 10:33 AM
  #32
DanRC's Avatar
DanRC
Engine temp scensor would have been one of my first thoughts due to the symptoms. Fuel starvation is usually the other way around. I noticed that the temp scensor was metioned before and that would have been the easiest to check ($40 and about 5 min.). I would have done that before taking the tank apart.
Old Jul 1, 2016 | 10:35 AM
  #33
svarnster's Avatar
svarnster
I don't think it is unique to flhs, it is just what I have. Why?
Old Jul 1, 2016 | 10:41 AM
  #34
svarnster's Avatar
svarnster
I have thought it to be electrical all along until the last ride when stopping and getting gas fixed it for 15 minutes which could be a result of the bike cooling down enough for the temp sensor. is there a test for temp sensor? I am reading manual to check thanks. It almost acts like the fuel system is in a vacuum not allowing fuel to flow freely,which is why I took tank apart
Old Jul 1, 2016 | 11:20 AM
  #35
Zerk's Avatar
Zerk
Myself, I'd put it in a related technical forum, that would get the most exposure.
Old Jul 1, 2016 | 05:31 PM
  #36
svarnster's Avatar
svarnster
thanks that is a good idea
Old Jul 2, 2016 | 11:25 PM
  #37
svarnster's Avatar
svarnster
is there a way to test the temp sensor?
Old Jul 2, 2016 | 11:34 PM
  #38
svarnster's Avatar
svarnster
I have checked all the hoses in the tank for pin holes, none. I have checked flow of filter, seems fine fuel flows thru it easily. the pick up strainer looks to be in good working order. The cross over holes feed flawlessly, drained tank by siphoning the left side and it emptied both sides. I have cleaned breather element, cleaned the throttle body, cleaned all the chrome in the area. along with everything else.
Old Jul 4, 2016 | 02:50 AM
  #39
svarnster's Avatar
svarnster
shes back together will ride this afternoon to see if it worked. I also cleaned iac
Old Jul 4, 2016 | 05:35 PM
  #40
svarnster's Avatar
svarnster
rode 10 miles pulled clutch and plop plop plop and died. turned ignition switch off waited 30 seconds and she fired up and ran good for about 5 miles, I stopped turned ignition off 30 seconds and fired back up and ran good the last 5 mile back home and continued idling when sitting in driveway.
