After maket headpipe or decatted headpipe
Old Jun 11, 2016 | 04:36 PM
mxz600's Avatar
mxz600
Default After maket headpipe or decatted headpipe
Need your thoughts on this. I have a 2016 Ultra Limited and just put on Cobra 909 mufflers. They sound great by the way. Not too loud but enough bark when you need it. I have thought about decatting the headpipe and maybe putting on some xied's by Nightrider. Could do this for under $300. Dealer suggest a Cobra powerport headpipe, stage 1 air cleaner kit, and screaming eagle super tuner to the tune of $1400. My question is the $1100 difference really worth it. I live in Michigan and average about 12,000 per year. Thoughts please!!
Old Jun 11, 2016 | 04:43 PM
Uncle Larry's Avatar
Uncle Larry
Decat the head pipe yourself ( you will notice an increase in the exhaust noise ). Forget the XIED'S. Install an aftermarket A/C kit and vent the breather to atmosphere. Install a Power Vision ( go through Fuel Moto ) and run it through the "Auto Tune" process .... and use the savings for a fabulous trip. 12,000 miles average in Michigan is a good number.
Old Jun 11, 2016 | 04:46 PM
Uncle Paul's Avatar
Uncle Paul
Very small performance difference between the two systems, and a huge difference in price.
Old Jun 11, 2016 | 06:22 PM
PSRumors's Avatar
PSRumors
I am running a stock decatted head pipe and vieds. This makes for a very decent ride. Bike is much cooler and runs better. BUT this is just a stop gap measure on my way to a dyno tune. The vieds are good but do nothing for full throttle performance (open loop) and leave a lot of performance on the table when cruising around (closed loop). A dyno tune is the way to go but if your just looking to kill the cat this is a cheap option.
Old Jun 11, 2016 | 06:52 PM
smitty901's Avatar
smitty901
A good 2-1-2 header is better but nothing wrong with a De-catted header if done right.
Xied's are a Band-Aid not a cure
Old Jun 12, 2016 | 08:24 AM
billnourse's Avatar
billnourse
There is about 1.8 HP difference between a 500 dollar 2-1-2 head pipe and a free gutted cat. If you are not going to do a lot of upgrades I would go with the gutted cat.
You can gut the cat for free if you know a welder that will weld the window up for you. Plenty of examples of this mod on the forum, or I can post instructions for you. You can usually buy one for 100 exchange.
An air cleaner is 150 and you can put it on yourself, and a Power Commander 5 with a tune from Fuel Moto is 270 and a Power Vision is 450. Either of these you can install yourself. I have the Power Commander 5, but would go with the newer Power Vision of I were doing it again. And you already have mufflers.
So for 520 to 700 you can have a really good running bike that is considerably cooler than factory and a lot less than most dealers want for the same mods.
Bill
Old Jun 12, 2016 | 11:21 AM
Beaux's Avatar
Beaux
Doesn't matter ............... I have both, as mentioned any advantages are minimal. Save money and gut.
Old Jun 12, 2016 | 11:39 AM
jt metal's Avatar
jt metal
www.superflowmufflers.com
Old Jun 12, 2016 | 11:53 AM
OldPhat's Avatar
OldPhat
Cobra Powerport Duals would be good, not so much gain in air flow with Stage-I AC.
Add a K&N replacement filter to the stock AC housing, (part # HD-1614 @ $60.oo) will
feed all the air your engine needs. Nightriders FL-ViED-10 will richen up the fuel also.
That makes a low cost Stage-1 for your2016 Ultra Limited.
Old Jun 12, 2016 | 12:04 PM
ericl's Avatar
ericl
I changed my 2010 head pipe to an 09 pre cat. I did stage one and it was ok, what's gonna wake up the pipes and give you HP is a good cam swap, doing it yourself keeping stock lifters, your gonna be in at around $400-$450, cams, Orings/gaskets, bearings, cams. You will be impressed with the sound and the numbers
