Right floorboard spacer/screw
Old Jun 13, 2016 | 09:05 AM
jkeeton81's Avatar
jkeeton81
Default Right floorboard spacer/screw
Couple months back I put some Arlen Ness pipes on my 15 SGS, which required the floor board be moved out a bit. THe pipes came with a longer screw and a spacer. I apparently forgot to throw some locktite on and yesterday the screw came out while riding and I lost it with the spacer. Anyone know if there are spacers I can purchase or do I have to contact Arlen Ness?
Old Jun 13, 2016 | 12:20 PM
mkguitar's Avatar
mkguitar
you can find spacers of various sizes at ace hardware
Mike
Old Jun 13, 2016 | 12:24 PM
jkeeton81's Avatar
jkeeton81
Well I thought I needed a special one because there is that little notch on the pedal board mount.
Old Jun 13, 2016 | 12:25 PM
GTK's Avatar
GTK
Mike
And also the correct threaded bolt that fell out.
Old Jun 13, 2016 | 12:35 PM
Toofat's Avatar
Toofat
Just use some washers. If the front bolt is the one you lost, just use the back bolt spacer for the front and put washers on the back bolt. Can't see back bolt spacer when mounted, so no one will know you used washers. I bought a used exhaust, no spacers came with it, so have two washers on both bolts on my floorboard.
Old Jun 13, 2016 | 12:38 PM
jkeeton81's Avatar
jkeeton81
OK thanks, Its the back one thats missing but I just need to get a longer bolt. I could care less what it looks like really.
WRE4U
Jul 5, 2016 05:53 PM
kozy22
Oct 29, 2010 02:06 PM
mblackmon
May 2, 2010 04:38 PM
Roadie4
Apr 29, 2007 12:48 PM
heavypic
May 19, 2006 09:21 AM
