Pull engine trouble codes
Old Jun 21, 2016 | 04:27 PM
Vernal's Avatar
Vernal
Originally Posted by Hawk66
Jumper doesn't work on 2002 according to dealer. Should maintain a history that can be pulled with scanner according to them.
I know jumper didn't work for me.
I'm no expert on retrieving codes from that year bike but there are several posts about doing it from some pretty savvy guys. Check out this link by DR. Vtwin:
https://www.hdforums.com/forum/softa...des-dtc-s.html
The reason I suggest carrying the jumper with you is I recall reading that with this method you can only retrieve current DTC's not historic, so if it happened and you stopped could you get the DTC while it was still current? Historic DTC's are cleared after 50 ignition cycles lasting at least 30 seconds.
If you do go to the dealer to have it read make sure you had the engine light come on in the last 50 Ign cycles.
I hope others will add to this if I'm mistaken.
Bill
Old Jun 22, 2016 | 10:28 PM
GoofySB's Avatar
GoofySB
Jumper wire worked fine on my 2002 RK. It shows the historic codes too. Made my jumper wire with 2 insulated female spade terminals. worked fine. Tried again just using 1 terminal to jump the pins. That didn't work. Back to 2 and no problems.
Clifford Barker
Apr 13, 2019 07:47 PM
frogwash
Oct 5, 2011 08:01 PM
eja
Nov 4, 2010 07:13 PM
keith kaupp
May 29, 2010 07:04 PM
daboys53119
May 19, 2006 07:16 AM
