Bagger "Wobble"
Irode my Road King with the removable fairing from LA to Pismo Beach yesterday. North of Santa Barbara, on Highway 101, you can open it up quite a bit. I was cruising at 85-90 mph and my front end stated to shimmy, shake, wobble or whatever the correct term is. AlthoughI never felt as if I was going to lose control of the bike it was quite violent and uncomfortable. It seemed to pick up a harmonic vibration that fed on itself and would increase in intensity to where I would lose contol ifI did not back off. Interestingly enough ifI backed off, say to 70, it would continue to wobble but as soon asI gave it some more throttle and went back up to 75 the wobbling stopped. The bike has only 10,000 mi on it and has been recently serviced by an independent technician who I consider above average so I don't believeI have any exessive wear or maintenance issues. I don't believe it is caused bythe removable fairing as I have an 07 Ultra and can run all day at that speed with no issues.
My question is does this sound likea problem that would be solved by the Alloy Art's Touring XR Stabilizer or similar product? Or is it possibly an aligmnment ora front fork bearingproblem?
The problem you are describing does not sound like the rear steer that the Alloy Art, True-Track, Ride Str8 products are designed to improve. Your experience sounds more like a front tire, wheel bearing, or steering head problem.
Even though you only have 10K on it, and you indy just serviced it, I would check everything up front.
Just my 2 cents.
Do you have wheel weights on your wheels?
Second post I've read in two days regarding "wobble" and I am beginning to worry a bit as I don't have weights on my wheels, but haven't ridden it yet..[
] I hope I don't have any problems after spending all this money on my bike to make it look decent but having it ride like sh!te![:@]
There is some good discussion on the abovethread. My explanation of the dynamic is thru a trike reinforcment failure, but should help explain the dymanic involved. This subject for some is like taxes and religion; all BS. For others, not so much. Think about it, then rationally decide for your self. Straight line speed is 'not' the issue with Tank Slapper, Wobble, whatever.
[IMG]local://upfiles/17522/286DEB9E5A4447B89D111F55C025597A.jpg[/IMG]
I have seen this subject discussed on other posts here. I can't say I still understand the issue completely.
What size rear wheel/tire combo are you running. That could be the culprit. Looks pretty low so I assume it's stock. If so then disreguard my post.
I measured the rear wheel in the swingarm on both sides, (it was lined up fine). Measured from the front axle to the rear axle on both sides and was off almost 1/8".
Replaced the front motor mount (that was worn) with a new one and set the turnbuckle to the correct length to get the bike "square" from the front axleto the rear axle on both sides.Replaced the top engine turnbuckle and adjusted that to ensure the engine was in the correct vertical plane, that turnbuckle was worn as well. All of these steps are outlinedin the factory manual. Then topped off the tires to 38psi front and rear. Since then, I have had no more wobbles for the past 12k.
