Hey Guys 2009 UC, Crusie control RESUME and ACCEL does not work however everything else does The SET and the DECL with the switch. Took it to my Dealer all seems to work will with no codes. I am so frustrated it also disengages properly with all functions brakes , clutch etc...anyone have the same issue?
I'd probably start by making sure the pin for that wire in the plug in the fairing is making contact with it's counterpart in the other half of the plug. Maybe check the continuity on the wire from the switch to its end, wherever that is. Finally if one of that works but the every other switch works, well then maybe the switch took a dump and needs to be replaced. Look on like eBay, should be a fairly easy replacement.
This is taken from the 2011 Touring Electrical Diagnostic Manual. I don't know if you can test it without a Breakout Box.
DTC P0577 PART NUMBER TOOL NAME HD-48637 BREAKOUT BOX Table 5-7. DTC P0577 Diagnostic Faults POSSIBLE CAUSES Short to voltage in cruise set/coast circuit Cruise resume/accelerate switch malfunction Cruise set/coast switch malfunction Short to voltage in cruise resume/accelerate circuit 1. Cruise Set/Coast Circuit Voltage Test 1. Connect BREAKOUT BOX (Part No. HD-48637) between wire harness [78B] and ECM [78A]. See 1.2 DIAGNOSTIC TOOLS. 2. Turn IGN ON. 3. Using a multimeter, measure voltage between breakout box terminal 22 and ground. 4. Is voltage greater than 1.0V? a. Yes. Go to Test 2. b. No. Go to Test 3. 2. Cruise Set/Coast Switch Test 1. Disconnect right hand controls [22]. 2. Measure voltage between breakout box terminal 22 and ground. 3. Is voltage greater than 1.0V? a. Yes. Repair short to voltage on (BE/BK) wire. (5041) b. No. Replace Cruise Set/Coast Switch. See the service manual. 3. Cruise Resume/Accelerate Circuit Voltage Test 1. Measure voltage between breakout box terminal 34 and ground. 2. Is voltage greater than 1.0V? a. Yes. Go to Test 4. b. No. See diagnostic tips. 4. Cruise Circuit Voltage Test 1. Disconnect right hand controls [22]. 2. Measure voltage between breakout box terminal 34 and ground. 3. Is voltage greater than 1.0V? a. Yes. Repair short to voltage on (W/BE) wire. (5041) b. No. Replace Cruise Resume/Accelerate Switch. See the service manual.
