Just removing slipon cones
Old Jul 4, 2016 | 07:33 PM
CdnArmyGuy's Avatar
CdnArmyGuy
Default Just removing slipon cones
Ive read that someone just removed the cones on a stock slipon. But never heard anymore. Anyone just do this and leave the filler. So they dpnt sound tinnie. Its on a 2016 limited.
Old Jul 5, 2016 | 05:10 PM
CdnArmyGuy's Avatar
CdnArmyGuy
Anyone
Old Jul 5, 2016 | 06:16 PM
mkguitar's Avatar
mkguitar
a good many have gone at the stock mufflers- and there are posts.
I would try to sway you away from this as random exhaust mods will give random results-
the exhaust as a system is ( or should be ) designed to retain high exhaust gas velocity- managing what happens to the exhaust can make a huge difference in power- not only how much power is produced, but at which rpms power is gained...or lost
I would suggest that if you still have the stock header that you get one with the catalytic converter removed- this will remove the bottleneck to flow in the exhaust system.
ebay, about $150 US
some riders are happy with the stock mufflers once the cat is gone.
There are also tutorials here on the forums to do this- can you or a buddy weld?
this will give a better, more predictable performance result- for this change you will likely to to alter the mixture slightly
nightrider.com xieds/vieds will do it at low cost
say hi to Jumbo for me!
Mike
Old Jul 5, 2016 | 06:36 PM
CdnArmyGuy's Avatar
CdnArmyGuy
Thanks
Looking going true duels. Till thevwife gets hers next yr. Just like to keep the noise down. Just looking for a lil more than stock.Have gone through many a post. I know gutting it complete is over kill.
Old Jul 5, 2016 | 06:45 PM
mkguitar's Avatar
mkguitar
there are many considerations- if you are stuck on a TD's ( which I never suggest), you'd do best with a comprehensive system- at least that way if you are struggling to tune the bike the vendor will have a known quantity to deal with.
fullsac does a kit which is cost effective
TD's seem to be for those whose priority is conception of a "sound" they are looking for
those looking for power use a 2/1 for a torquey bike, and makes sense for a Decker- but you live in flat land, you'll not be carving canyons or cresting mountains every day- or charging through city traffic
a 2/1/2 will give better power result thru the rpm range
my suggestions will always fall on the conservative side- reliability ...and cheep!
Mike
Old Jul 6, 2016 | 05:47 AM
CdnArmyGuy's Avatar
CdnArmyGuy
Mike
I know just changing the exaust not a big retune required. Neighbour de catted and used his stock gutted ones for a while. But loud as crap. Its a street glide so no biggy.
He never retuned. The cat should keep the back pressure. Its more if its going to sound tinnie. Going with a set of duels and Cobra tourers next yr. So no tune required.
Old Jul 6, 2016 | 07:50 AM
Joe12RK's Avatar
Joe12RK
you will get a little more sound from the stock mufflers if you get rid of the catalytic converter
Old Jul 6, 2016 | 09:10 AM
Hate Work's Avatar
Hate Work
+1. That "a little more sound" is very noticeable. If you truly are looking for just a little more sound, that is a very good way to go.... plus adjusting the fuel/air mixture.
6 gun
Mar 3, 2018 07:37 PM
Windseeker
EVO
20
Jan 9, 2018 09:30 AM
FL54
Shovelhead
Feb 2, 2017 07:15 AM
Matrix
Feb 19, 2014 12:12 PM
6speed
Oct 9, 2006 09:56 PM
