Brake problems
Old Jul 9, 2016 | 01:17 PM
John Sitek's Avatar
John Sitek
Stage I
Default Brake problems
I have a 2003 Harley Davidson Ultra Classic. My problem is, when I turn the bike on, the brake lights are already on. When I hit the brake lever, the lights go off. Far from electrically inclined. Plungers on handle have been cleaned and loosened.
Old Jul 9, 2016 | 04:52 PM
ORradtech's Avatar
ORradtech
Have you checked both front and rear?
Does the front lever return fully out when released?
Try disconnecting the wiring at the rear brake switch.
I've read that the wiring to the light under the rear fender can be a problem., might want to check there.
Old Jul 9, 2016 | 05:37 PM
mkguitar's Avatar
mkguitar
the front brake light switch is easily broken if the right side controls are removed from the bike without a shim being used to protect the switch
----- this is common for anyone who doesn;t check the manual- a few guys have been able to effect a fix with a small scew or jb weld.
there are posts and pics here on the forums
replacement switch is about $60
welcome to the forums
Mike
Old Jul 9, 2016 | 06:12 PM
hardheaded's Avatar
hardheaded
has anyone had it apart lately ? isolate it to either the front or the back and then work from there.
Old Jul 9, 2016 | 09:27 PM
sn95bullitt's Avatar
sn95bullitt
I put a little jb weld on the lever. Works good as new. Change the switch but I have internally wired bars and don want to mess with it.
t059736
Sep 28, 2013 12:52 PM
Mikey d 44
Aug 18, 2013 10:19 AM
harleyrider07
Jan 18, 2011 10:36 AM
tidefan60
Apr 23, 2010 01:45 AM
95Heritage
May 27, 2007 09:46 AM
