Going naked
Old Jul 10, 2016 | 03:15 PM
Glideright's Avatar
Glideright
5th Gear
Default Going naked
I have a 2015 SGS. I'm running V&H Oversized 450s, V&H V02 Grenade AC and FP3. Just curious if anyone has had any issues with the naked set-up as far as performance, when you're surprised by rain, what set-up you went with on the FP3, etc. I know the FP3 has a set-up for running slip-ons, but is there an alternate set-up when the naked AC is introduced. Thanks for whatever input you can provide.
Old Jul 10, 2016 | 03:55 PM
Ultraboy105's Avatar
Ultraboy105
Was told that there isn't enough difference, the tuner doesn't care.
Old Jul 10, 2016 | 04:00 PM
Glideright's Avatar
Glideright
5th Gear
Roger that. Thanks..
Old Jul 10, 2016 | 04:13 PM
elky72ss454's Avatar
elky72ss454
I run open element breathers on my bikes. Rain is not a problem while the engine is running. If it sits outside in a rain, it will soak the element, then you will have a problem. Might want to cover it when parked if expecting rain. I cover mine with walmart bags...L...Might look stupid but it works. If it gets wet, need to pull it off and blow it dry, should be good to go.
Old Jul 10, 2016 | 04:19 PM
Glideright's Avatar
Glideright
5th Gear
Good info. Thanks..
Old Jul 10, 2016 | 04:20 PM
Glideright's Avatar
Glideright
5th Gear
I got plenty of Wal Mart bags!
Old Jul 10, 2016 | 08:07 PM
DeneFXDWG's Avatar
DeneFXDWG
Just curious why you changed cleaners? Was it a performance thing because you weren't getting enough through the stock one to feed 103" or was it looks?
Old Jul 10, 2016 | 08:23 PM
Glideright's Avatar
Glideright
5th Gear
It was primarily for looks, and I figured I could get max air intake that way. The V02 Grenade looks great.
Crimson
Audio Systems
May 27, 2015 05:37 AM
rickdavis
Jun 17, 2014 02:13 PM
The Cheesehead
Dec 29, 2013 04:16 PM
monumaker
Aug 13, 2010 12:37 PM
fayad.said
Mar 23, 2008 03:20 PM
