Road King Accessory Switch
Old Jul 14, 2016 | 06:31 PM
TooTall2's Avatar
TooTall2
Default Road King Accessory Switch
Can someone tell me where the accessory switch on the 08 Road King (Classic) wires are located. I want to use this to power some 12 volt stuff. Is it under the tank?? Any help appreciated.
Old Jul 14, 2016 | 08:17 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
under the seat, in front of battery just below the tank mount. small plastic box 4 wires in one end and a rubber cap on the other. under the rubber cap 4 small holes, these use duetch connecters.. u can use crimp ons or get the harness from dealer. 4 hoes one is switched from ignition one from aux one from brake.
Old Jul 14, 2016 | 08:46 PM
bdtaylor1979's Avatar
bdtaylor1979
That's where it is on my bike.
Old Jul 15, 2016 | 12:44 AM
TooTall2's Avatar
TooTall2
Thank you very much!!!!
Old Jul 17, 2016 | 01:28 PM
TooTall2's Avatar
TooTall2
Thanks I found the 4 pin one. Do you know how the ground is routed or is it a frame ground?
What's the difference between a dirty and clean ground
and
There is a gray connector with a single red wire in it, any idea what that's for.
thanks for the help.
PS: I do have a service manual but I'm still an idiot.
Old Jul 17, 2016 | 02:48 PM
Vernal's Avatar
Vernal
It's not in the 08 manual that I could find, this is from the 2014 manual:
Old Jul 17, 2016 | 04:13 PM
TooTall2's Avatar
TooTall2
Thank you very much. That helps.
Old Jul 17, 2016 | 05:10 PM
ORradtech's Avatar
ORradtech
One of the 4 pins in the accessory plug is a ground. The others are on with ignition, on with ignition and accessory switche and a brake light wire.
The single plug with the red wire is a B+ line, meaning 12v constant. It's only fused through the main 40A fuse. Great for things that use a heavy draw or that you want to be always powered like a power point.
Old Jul 17, 2016 | 05:39 PM
RKZen's Avatar
RKZen
This might help
Old Jul 17, 2016 | 06:06 PM
TooTall2's Avatar
TooTall2
Thanks for the replies
maryv
Mar 25, 2017 10:31 AM
1dwmksmith
Jun 14, 2016 08:28 PM
driv3rx
Feb 9, 2016 02:52 AM
oliver99
Mar 28, 2010 04:56 PM
MDMYMD
Apr 1, 2006 12:17 PM
