Does this come complete with new springs. If not should the springs be replaced? I have 40,000 and comp is making some noise and I'm having some hot start issues Thanks Bob
I was planning on using the regular cure JB weld it is unaffected by heat to over 500 degrees according to info on package. Of coarse I'm planning on proper preparation to insure bond. Thanks for info
I looked at the instruction sheet for the Baker unit. It appears as though you don't have to remove the Rotor or inner primary to install the Baker Compensator? Is this correct? Thanks R.
If you have a 2011 or newer, you should already have the updated rotor.
