No, I used a heavy weight nylon bag I already had. It's rectangular and zippy closed. For the tire kit I bought a compressor kit that came with a rubberized semi hard case and added the plugs, plug tools, tire guage and knife to it.
I went with a compressor rather than the co2 cylinders because from reading it looked like it would take 4-6 of them to get the tire rideable and the compressor is reusable incase I cannot get the leak stopped. I used it on a buddies bike and was very impressed with its operation. It hits very hot though. It's a "Slime" kit but I don't use the Slime, just the compressor.
Wire cutters for cutting tie-wraps, bailing wire, etc. Won't need them 99 times out of 100 but when you do they're worth having in the kit.
Thanks for the clarification . That helps.
Originally Posted by Prologix
Do not know yet, just started to build it last night, as in I received a canvas tool roll from etsy in the mail, now time to fill it.
Sometimes, it's a thin line trying to keep common tools while still keeping it contained to a small size.
I've looked at those Slime compressors at Walmart and always wondered if they were any good. Good to know that they do the job well.
I researched them quite a bit and reviews were pretty much the same no matter the cost. I figured if the $100+ ones failed as often as the cheap ones I'd just go cheap...
hate to sound like i am pushing harley brand but thier 8 in 1 screwdriver (made by snapon) is the one thing I have on every bike. it has flat phillips and torx bits in one handle.
I also carry a small adjustable wrench , small vise grips , 3/8,7/16 1/2 and 9/16 wrench and a set of allen keys, one of the free harbor freight flashlights. not really tools but also a roll of electrical tape , a assortment of fuses , a piece of insulated wire, and piece of mechanics wire , and a spare tailight bulb, and a few zip ties
I was on a trip this sunday and had to get into the tool kit twice. Once someone needed some electrical tape, then we had to load a bike due to a sick rider and had to remove bolts holding a truck tool box in place. I'm not a wrencher anyway, but It's a little bit of piece of mind.
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Have you tried the Knipex Pliers Wrench ?
The 86 03 180 is a clever travel companion.
My experience with the tool roll was not conclusive. It deteriorated rapidly while bouncing in the saddlebag.
I bought a windzone tool kit back around 2002.Has just about anything you'd need in it tools,wire plug sockets,etc.I've tried to look em up but don't know if they're still in business.
