I researched them quite a bit and reviews were pretty much the same no matter the cost. I figured if the $100+ ones failed as often as the cheap ones I'd just go cheap...
Good point. Only thing is that with some tools (especially back when I was an active off-roader with Jeeps), you'd see people with the cheap Harbor Freight winches that would fail at a crucial moment. The last thing you want when you have a breakdown is a tool that fails as well.
I rec'd the RoadTech H3 kit as a gift and I am happy with it.
Looks like a nice kit.
Originally Posted by SIDECAR BOB
hate to sound like i am pushing harley brand but thier 8 in 1 screwdriver (made by snapon) is the one thing I have on every bike. it has flat phillips and torx bits in one handle.
I also carry a small adjustable wrench , small vise grips , 3/8,7/16 1/2 and 9/16 wrench and a set of allen keys, one of the free harbor freight flashlights. not really tools but also a roll of electrical tape , a assortment of fuses , a piece of insulated wire, and piece of mechanics wire , and a spare tailight bulb, and a few zip ties
I do like this screw driver. And a decent price to boot.
I was on a trip this sunday and had to get into the tool kit twice. Once someone needed some electrical tape, then we had to load a bike due to a sick rider and had to remove bolts holding a truck tool box in place. I'm not a wrencher anyway, but It's a little bit of piece of mind.
That looks like a decent kit - I've had some Stockton tools in the past and they are decent quality. And you're right - buying the tools individually would probably cost quite a bit more.
Originally Posted by Expat1
Have you tried the Knipex Pliers Wrench ?
The 86 03 180 is a clever travel companion.
My experience with the tool roll was not conclusive. It deteriorated rapidly while bouncing in the saddlebag.
Looked at that - is it an adjustable wrench with a plier-like action? As far as the tool roll, the reason I wanted something that could be rolled up and strapped down was to prevent them bounching around and eventually losing bits, sockets, extensions, etc.
Originally Posted by piper59
I bought a windzone tool kit back around 2002.Has just about anything you'd need in it tools,wire plug sockets,etc.I've tried to look em up but don't know if they're still in business.
In addition to what's already been mentioned maybe a few band-clamps.
Band clamps?
While on this subject, I know a few mentioned carrying extra fuses, bulbs, etc. Has anyone needed to carry a spare headlight bulb? Or an extra quart of oil or other miscellaneous emergency rations?
I carry fuses, not bulbs. I don't think bulbs would hold up well.
I check oil before I leave. If I need a quart it's probably not a side of the road thing
I carry a slime compressor and a mushroom plug kit. I have used it on mine and several others while riding out in the middle of nowhere. I have a carhart tool roll that has most of what others have described here. Make sure you get an allen for a ratchet that is long enough to loosen and tighten the bolt on the front inside gear lever of the shifter shaft. They come loose often. Also, if you need to remove the front wheel for any reason you need a 10mm 12pt socket for the brake caliper. I disagree that you can't do much on the side of the road. We have loaded bikes in the back of a farmer's pickup and had parts overnighted to the hotel to fix it the next day. It saved a week of riding in a remote location. No shop within hundreds of miles.
