I read all the time that if you are getting popping/backfire on decel then you are running lean. Who ever came up with that? [:'(]That is sofar far from the truth it isn't even funny. If anything your more likely to running on the rich side if getting the decel pop/backfire. As some/many (time will tell)of you knowa pop/backfire out the pipe is nothing but O2 being sucked in to the exhaust somewhere i.e. a leak and igniting unburned fuel in the pipe, the end result is a small explosion/pop/backfire. If your running lean, not enough fuel, then how does that even make sense, Decel popping equals lean? [:'(]Ever go to your local short track and watch the Sprints, Modifieds, Latemodels, etc. Man when they let off before the turn, that methanol lights up such a pretty blue, with the air being sucked in and the fuel being burned off.
If a person went by your theory then all of these lean running 07's would run better after installing better flowing air cleaners and pipes with no other fuel alterations because they would now be running even leaner than they were stock and would have no decel popping and if they did then they would need to lean them out even more because as you said they must be running rich. A lot of people on this forum including my self have eliminated the decel popping after installing after market pipes, air cleaners and ecm maps by adding fuel to the f/a ratios at the rpms where the popping is taking place. According to you we should have made the decel popping worse. And no I didn't have any air leaks at the headers, mufflers or intake.
Zippers Performance Parts sells a piece that you put into the left side split of the rear cylinder header pipe (if so equipped). It's called a pop-stopper. What it does is constricts the pipe down to a hole the size of a dime. Since most exhaust goes out the right side anyway it even helps the stock pipes act like a 2 into 1 system. Now I have not tried the product and what I just spouted is all theory. But it sounds good. I couldn't find the product on their website either but I have one in my hand. Paid $7 for one but didn't install it when I put on my V&H Ovals. I'm also running PCIII and have not heard any backfiring.
From the package: Reduces inbound fresh air reversion which causes excessive decel backfiring. Remove left muffler, install in headpipe at muffler joint.
If you wish to call and discuss the product with them their number is 410-579-2828. Let us know if you end up using it. I'd like to quit moving it from one part of my workbench to another. Either install it or throw it in the garbage.
Not sure where i posted that you should put on a air cleaner and pipes without giving it more fuel? I said "IF ANYTHING" it's on the rich side. Not sure how you go about getting a pop/backfire without unburned fuel and O2 being present? I have TD's on my bike, SE air cleaner Rush 1.75's and i get a pop/backfire out the left pipe quite often. Bikes running great, plugs are perfect color. I reach my hand down to where the muffler clamps on to the end of the tail pipe, black carbon on my fingers. It's sucking in some air where the left muffler clamps on to the exhaust pipe. No lean condition for me. But i do get a pop out of the left side.
I do think the decel popping is caused by a lean condition. My understanding is that it is caused by unburned fuel (in the exhaust gasses) igniting in the head-pipe. I may be wrong, but I thought that richening the fuel-air mixture brings the amount of unburned fuel up to a level high enough that it is too rich to ignite in the pipes. Maybe someone can confirm or dispute this.
Having said that, I also think that waaaay to much emphasis is placed on the supposed detrimental effects of a little decel popping on the bike/motor. I am just not convinced that it causes harm to the engine. There has been a lot of speculation, but nobody here has been able to PROVE that it has caused a failure in their motor.
Correct, Too much fuel and not enoughO2 and you are 100% correct it will not ignite, pop/backfire. Get acup of gas and throw a lit cigarette in it. Nothing will happen except the cig will go out. My bitch is that it's almost a automatic statement that if your getting a pop or backfire you are lean. Bull ****. There are plenty of other variables to consider.
Tech2, Response2, But even if your motor is setup perfect, and the air fuel mixture is right on the money,but you are sucking in some air in to the exhaust,it's going to pop/backfire. I'm just trying to break this OMG your getting a decel pop/backfire [] then you arelean condition.
