A Thought --- UPDATE
Old May 23, 2007 | 10:07 AM
ndotken's Avatar
ndotken
Default A Thought --- UPDATE
I just flipped 10K miles on my '07 RKC and I have just not been happy with the performance of the engine. This is my fourth Harley after owning Honda's. I like the feel and sound of my bikes when I'm cruising at around 2,000 RPM's, but this bike with the TC96 will just not do it. It obviously labors at anything below about 2,500 RPM's, especially in the taller gears. Yesterday I'm doing 50-55 in 5th gear and the bike isn't lugging, but I can tell it's not comfortable there either. I had a thought that the stroke is too long and that maybe boring out the cylinder to 103" will help the bike in the lower RPM's. Any opinions?
Has anyone done a 103 upgrade on an '07 and did it help? Did you change the cams or heads?
Old May 23, 2007 | 10:09 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: A Thought
I'd swap to 3:37 primary gearing.
Old May 23, 2007 | 10:18 AM
04harleyboy's Avatar
04harleyboy
A longer rod should produce more torque, with all other things equal. Do you have the stage I done?
Old May 23, 2007 | 10:24 AM
ndotken's Avatar
ndotken
Yes, I installed SE air cleaner with PCIII and Rush slip ons at about 3K miles. That helped a little and reduced engine heat, but not in the lower RPM's.
Old May 23, 2007 | 10:35 AM
Hardly Dangerous's Avatar
Hardly Dangerous
I don't get it. Why ride at 2000 RPM's?They just don't like it. Bring it upa bit andall will be good. You'll just have to get used to it. It's the nature of the beast!
Old May 23, 2007 | 11:17 AM
Beancount1's Avatar
Beancount1
I found the same situation with my 07 RK after owning Honda shadows. It doesn't have a tack, but with the RK I find that the upshifting points need to beabout 10mph higher than the manual indicates. I also agree that cruising at 2000 rpms is on the low side.
Old May 23, 2007 | 12:36 PM
HogBoy's Avatar
HogBoy
Ditto. This beast doesn't like to run at low rpms. She's a lot happier running than cantering.
Old May 23, 2007 | 04:28 PM
jethro001's Avatar
jethro001
I have a 07 RKC with the 103 kit in it. When I am running at 50-55 I am usually in 4th gear. Your RKC is not going to run like a Honda. The dealer that put the 103 in said that you will notice the difference at the top end not the bottom. I love my RKC and would not ride anything else......
Old May 23, 2007 | 04:38 PM
st john's Avatar
st john
Things will come around and the right mods will be tryed and true.
Went through the same thing with shovel to evo and evo to twincam.
74 to 80, 80 to 88 ETC> just wait you will trading to an 08 or 09 before
you know it.
Saint
Old May 23, 2007 | 09:47 PM
ndotken's Avatar
ndotken
ORIGINAL: xxxflhrci
Dealership said HD does not yet have parts to switch to 3.37 primary gearing for the TC96. Said they can do it on '06 and earlier but not '07.
They suggested Drag Specialties. Anyone have any other recommendations?
