Handlebar problems
Old Aug 16, 2016 | 06:08 PM
feguy1's Avatar
feguy1
Default Handlebar problems
I was wrapping up a 10 inch bar install on my 2012 flhtc and I have no power with the ignition switch. I have 12 volts at the center wire at the ignition switch, but nothing on the other two when operating the switch. I can place a jumper from the center terminal to either of the other two wires and power up the bike.
Anyone have any experience with these? Or maybe have a wiring diagram you can send me? Thanks in advance.
Old Aug 17, 2016 | 06:06 PM
Whtwolf14's Avatar
Whtwolf14
When I put bars on my Dyna I had the same problem. Ended up being a grounding issue sense the bars were PC'd. Had to run a wire...
Old Aug 20, 2016 | 01:20 PM
feguy1's Avatar
feguy1
Got it!!! Ignition switch out of alignment! Flat blade screwdriver and patience.
1995 softail
Jan 31, 2021 09:44 AM
jackafrica
Electrical/Lighting/Alarm
Mar 10, 2015 04:53 AM
Damien Bessent
Oct 22, 2014 06:18 PM
Reef Rider
Jan 23, 2012 04:18 PM
crawfordcl
Sep 15, 2010 10:52 AM
