Initial starting issue
Old May 23, 2018 | 11:48 AM
Sparkee...'s Avatar
Sparkee...
My Glide began having the occasional hard starts and kick backs after a Stage 1 flash with the SE Pro Super Tuner. Further investigation showed the recommended map set the top row, the lowest RPM, of the ignition timing table to 0 degrees specifically the last 3 cells at the highest MAP columns. Retarding these 3 cells by 3 degrees eliminated any hard starts and the engine now rolls over much easier for cold or hot starts.
Old May 23, 2018 | 02:06 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Does this issue get worse as the weather cools down? I had an issue where i eventually increase my cranking fuel and it solved the problem. Until it got even colder then it was back. I looked at many other tunes (i have the Power vision so was easy to study. ) It bugged me that all tunes i had looked at didn't have to change the cold cranking values. Made me think logically that the only way the engine and computer know the temperature on startup is the engine temp. sensor in the back of the Front cylinder head. I replaced it and so returned my tuning to the stock settings and it fires right up so far now? Not saying that's what's wrong with yours but it helped me.
Old May 23, 2018 | 03:25 PM
woodthumb2's Avatar
woodthumb2
start with cleaning the air filter and changing plugs
Old May 23, 2018 | 07:44 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Can your dealer put their diagnostic tester on to see if your Automatic Compression Release is working?
Red Dragons
14
Apr 14, 2023 06:52 PM
tmultra
Apr 17, 2018 09:42 AM
bensonjv
Feb 28, 2010 01:30 AM
Figstr
Nov 26, 2009 10:37 AM
chopmafia777
Electrical/Lighting/Alarm
Sep 21, 2009 09:29 AM
