Air Scoop
Old Sep 3, 2016 | 06:13 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I recently something about removing the left side of the plastic thigh protector on the bikes. then the right side will help scoop air to the left and push the heat out on the left. This would be ideal while moving at turnpike speeds. I had my left hand down my calf/wife's leg and was amazed at the heat down there.
Old Sep 3, 2016 | 06:36 PM
White Ice's Avatar
White Ice
I've heard of doing this. The theory is that the two shields prevent air flow behind the rear cylinder. Removing one of them will allow cooler air to pass through. ....and you can't see both sides at once.
Old Sep 3, 2016 | 09:38 PM
head's Avatar
head
Originally Posted by mkguitar
3.) shovelhead era a metal scoop was sometimes used on teh left side- that woul dbe the place to add a scoop depending on horn/air horn etc
mike
I've used one of those on both of my last two Road Kings. Not sure how to properly measure if they made a difference or not. I didn't see how it could not help though.
Old Sep 3, 2016 | 10:07 PM
GregGillette's Avatar
GregGillette
I did this, removed the left side. Then my left thigh started warming up bad so I removed the right side too and left them both off. I originally installed when had the cat in place. Have since removed and never considered removing the mid frame deflectors but it makes sense now to keep off to keep rear cyclinder cooler. I dont notice much heat now unless prolonged stops
Old Sep 4, 2016 | 08:47 AM
Keithhu's Avatar
Keithhu
Seems pretty gimmicky to me. I'd pass.
Old May 2, 2017 | 05:23 PM
texaswiz's Avatar
texaswiz
I look at items like this and I think to myself "ya know self, if gizmos like this really worked as well as the marketing company says, then the MOCO would already have grabbed it up and they would be selling it for $129.00".
I did see one of these in a parking lot a couple of months ago. It is made out of heavy gauge, clear plastic of some sort.
Old May 2, 2017 | 08:29 PM
Veekness's Avatar
Veekness
1.) Hideous
2.) Hideous
3.) Hideous
​​​​​​​Besides all that, it's hideous
barrygreen
Dec 6, 2013 01:58 PM
ffron69
Touring Parts
Sep 10, 2013 05:49 AM
moparbobby
Sep 21, 2012 01:22 PM
