Thinking about Batteries plus for next battery. Their top battery is $159.00 with 24 month free replacement warranty. Think they have 10% off right now.
I've been running that battery for 3 years now. Good Stuff.
" The problem usually occurs with the pig-tail used to connect the tender."
BINGO!
Issue with pigtail connector is the round/female parts of the connectore almost always ends up with a bad/loose connection on male/spade terminal due to the femail part expanding over time/use.
Thats when guys buy new connector thats not needed,all i do is every so often using a pair of plyers over the female connecter lightly squeezing it to slightly narrow down the female/hole opening so it once again grips the male spade tighter for a good connection.
